What if a trucker has sleep apnea?
Discussion in 'Experienced Truckers' Advice' started by expedite_it, Mar 29, 2021.
  1. expedite_it
    expedite_it Road Train Member
    1,646
    863
    Sep 8, 2012
    I fear I might have sleep apnea as I am a heavy snorer, and I frequently feel fatigued. When I get a DOT physical and the doctor or nurse measures my neck size to check for sleep apnea, I always pass. But I fear I still might have sleep apnea.
    I believe that it might be possible to get one's medical card revoked if one has sleep apnea.
    My sister is a physician assistant, and she told me what would happen if I went to my primary care physician to be tested for sleep apnea. Hypothetically, let's say I go to my primary care physician (pcp), and my pcp issues me the test kit for sleep apnea. Let's say that the pcp then looks at the results, and my pcp diagnoses me with sleep apnea. Then my pcp refers me to a pulmonologist. The pulmonologist prescribes me to sleep with a CPAP machine (or however the acronym is spelled) on me to treat me for sleep apnea. What if a safety officer or the doctor who gives DOT physicals at my company or anyone else at my trucking company saw that I have to sleep with a CPAP machine (and thus knew that I have sleep apnea)?
    I am a solo company driver for a mega carrier.
    Would my employer likely fire me if my employer knew I had sleep apnea?
    If I get diagnosed with sleep apnea and sleep with a CPAP machine, is there any way I could notify my employer about this and still keep driving as an otr truck driver?
    tscottme and TallJoe Thank this.
  3. Chinatown
    Chinatown Road Train Member
    73,295
    164,752
    Aug 28, 2011
    Henderson, NV & Orient
    10's of thousands of truckers have sleep apnea. That isn't a disqualifier for a cdl.
    @Moose1958 and @kitcarguy can give you information on the CPAP equipment that a trucker must use to stay legal/compliant.
    meechyaboy, tscottme and slow.rider Thank this.
  4. rachi
    rachi Road Train Member
    4,246
    5,228
    Feb 25, 2010
    SoCal
    No, you won't get fired. I drove for nearly 10 years with a cpap machine in the truck, and I worked for 3 different megas and one small outft. If your a veteran you can get everything you will need (sleep test and cpap machine)
  5. Judge
    84,607
    Means you get a 1 year med card and get to put an inverter in truck to power the sleep apnea machine.
    tscottme, expedite_it and Chinatown Thank this.
  6. rachi
    4,246
    5,228
    Feb 25, 2010
    SoCal
    Right, I always got the one year card. If you don't use the humidfier on the device then you can plug it into the regular DC outlet.
    tscottme, expedite_it and Judge Thank this.
  7. Moose1958
    Moose1958 Road Train Member
    15,093
    33,183
    Dec 17, 2010
    Williesburg, Virignia
    OP first off hold on to those horses! Your primary PCP DOES NOT handle anything to do with your DOT physical unless of course, they are the one doing it. This sleep apnea business is one of my buttons to start with. So I am most likely not the person to be asking right now.
    My advice is to take stock of your health and ask yourself this question. Do you wake up tired and not feeling like you got a restful night's sleep? If the answer to this question is yes, then get a CPAP. If not then leave this sleep apnea thing to the ME that does the actual physical. Some MEs are honest and will just look at the form and maybe look at your throat.
    tnt440, tscottme, rachi and 1 other person Thank this.
  8. expedite_it
    1,646
    863
    Sep 8, 2012
    All of these replies have been very informative and helped a lot. Thank you.
    tscottme, rachi and Chinatown Thank this.
  9. lester
    2,914
    7,842
    Jan 2, 2012
    NW, Iowa
    I've had severe sleep apnea basically my whole life. And I'm skinny, so I don't buy that neck size thing. Anyway whenever I'm asked in my DOT physical if I snore or have any sleeping problems the answer is a strong NO.
    A few years ago I found a place online and did a at home sleep study. Had it and was given a prescription for a cpap machine which I use daily. I don't really understand why you need a prescription for the darn thing.
    I did this to keep the DOT away from anything to do with my sleep and because I don't have traditional health insurance that would have covered a sleep study. The at home test and cpap machine was relatively unexpensive
  10. Chinatown
    73,295
    164,752
    Aug 28, 2011
    The reason for a prescription is some insurance covers the purchase of the machine.
    slow.rider, rachi and tscottme Thank this.
  11. Brandt
    Brandt Road Train Member
    4,411
    5,949
    Sep 17, 2012
    If someone has sleep apnea and already has CPAP they just show the report that shows the driver is using it. They will give you a 1 year medical card. You just show them the sleep report every year or maybe lose weight and might not need CPAP anymore.
    slow.rider, tscottme and rachi Thank this.
