What happens when I run out of DEF?
Discussion in 'Questions From New Drivers' started by Burrito Warrior, Nov 12, 2016.
Page 1 of 3
Your truck will start running backwards.
It will slow down(de-rate) intitially, I can't tell what would happen with continued use .Balakov100, Puppage and tscottme Thank this. -
The truck will derate and finally come to a full stop. You will then be fired.
Rusty Trawler, austinmike, fargonaz and 2 others Thank this. -
How often do you guys fuel your DEF? DM usually neglects/forgets authorizing DEF and not sure whether to bug them or not when it is at 1/2.
Depends on how big the DEF tank is and how big your fuel tanks are. Did you fill up twice without getting DEF to bring the DEF level down to half?
You'll probably be ok to skip it. Can you get DEF in the box as an additive when you get fuel? It might be a good idea to try it just so you can keep a box under the bunk. -
That way if the def pump is broke or the hose won't reach I still have enough def til my next fuel upRusty Trawler, ncmickey, Ditch Doctor and 1 other person Thank this. -
Da mn, you need auth for DEF... Not easy being you now.
I usually get it at around 1/2 full indicated. There are some places that don't have bulk, and I wouldn't want to use the box; just looks awkward.MidWest_MacDaddy, skellr and mindes Thank this. -
fargonaz Thanks this.
I fill def every fuel up. If i fuel at a terminal, they don't all have def and some truck stops have def pumps that can only pump at a trickle so for me it's best to keep it full when I can.
There is a yellow light near the DEF gauge that will come on when it gets really low. probably gives you an hour before it starts flashing and derates the motor by 25%. Once it derates you don't want to turn the truck off until you get somewhere that has DEF. It probably won't let you go faster than 5mph if you try to run again without DEF.
Page 1 of 3
