what happen when you run out of DEF?
Discussion in 'Questions From New Drivers' started by zoekatya, Apr 2, 2014.
Page 1 of 6
The engine will most likely derate , truck may have to be towed , boss will be very pissed
Google nearest truck place , call them , get some DEF in the tank before the company
gets involved -
How much DEF is in the tank?Can you make it to the next truck stop?I wouldn't keep driving it.
zoekatya Thanks this. -
It will derate turn on check engine light and if ran long enough shut off the truck but once u fill it and cycle the key its not a big deal other then the logged code but it wont be active
Get to the nearest truck stop ASAP and fill it up to avoid serious issues.
Thanks everyone!
It will blow up , as in spontaneous combustion.
Proof gone !!!!!!!koncrete cowboy Thanks this. -
This is from my visor on my Volvo 780. I'm going to assume it's pretty much the same for all DEF/SCR trucks.
Solid DEF warning lamp
The DEF tank is low
Refill the DEF tank
Flashing DEF warning lamp
The DEF tank is empty. Engine is in derate mode.
Refill the DEF tank now (before adding diesel)
The DEF warning light is flashing + warning message on driver display
The DEF tank is empty. Vehicle is limited to 5 mph.
Refill the DEF tank now (before operating vehicle)
So you have some time to get it filled up once it's empty before you are FUBAR.yuban Thanks this. -
I carry an extra box...just in case
tangerineGT Thanks this.
Page 1 of 6
