I kind of understand that the fuel surcharge is an extra charge added to a rate to offset higher fuel prices. Not sure about the real definition or how it's calculated.
What exactly is fsc and how is it calculated?
Discussion in 'Ask An Owner Operator' started by gravdigr, Feb 25, 2012.
fuel surcharge is calculated on the mile if paid by the mile.
if you are paid by percentage it is a % of the gross over what your
your percentage is .
so if you haul 1000 dollar load gross and you get 75% you would
get 750 dollars plus the surcharge if it is 35% then that would be
350 dollars total to you before expense is 1100 dollarsAnother Canadian driver Thanks this. -
It's just a way to try and fool you, so you think you're getting something extra. Know what you need/want a mile and just figure it that way.
When these brokers start talking miles andsurcharge and all I know they
are jsut sugar coating a crappy load. Know your REAL miles and what you want and the rest is irrelavent.
The pay I want is like 1000 miles = 2500-3000 dollars
what you end up with most of the time
of late seems like 1000 miles = 2150-2300 still ok if you reload close by.
Now there will be those that say they make lots more, some may but most lie.Another Canadian driver and donkeyshow72 Thank this. -
When you are working off load boards/through brokers the fuel surcharge is useless, you just need to know the total amount coming to your truck.
The fuel surcharge is useful for when you have a long term contract. Say you contract with a shipper to haul their freight for $2 per mile plus fuel surcharge for fuel over $2 a gallon. The fuel surcharge rate will vary every week to compensate for the extra fuel expense because your rate only includes fuel at $2 per gallon. If this weeks fuel is $4 per gallon and is calulated at 5 MPG, you will charge an extra .40 cents per mile. ($2 over the base rate divided by 5)Another Canadian driver Thanks this. -
Not one broker gives a #### about a fuel surcharge I'm at $.55 a mile in 2003 just as fuel started going up I was at $1.90+ a mile to the truck in 05-06 when everyone started talking fuel surcharge I started using it customers got pissed about it most wanted a flat rate so no I should be getting $2.45+ a mile but that don't always happen on load boards
Paddletrucker Medium Load Member
Say it's based on 6mpg and $1.25/gallon. Fuel is 4.00/gallon.
1.25/gallon subtracted from 4.00/gallon equals 2.75.
Take that 2.75 and divide by 6mpg. You get.458, or .46 cents per mile.
In another thread BigBadBill said he believed we'd see that fuel mileage start to be based off of 7mpg, rather than 6mpg, and I think he's right. As we continue to see the industry's fleet fuel mielage average rise, they'll adjust the numbers accordingly.Another Canadian driver Thanks this. -
Fuel surcharge is a seperate charge intended to keep your fuel cost stable. Really it's based on an arbitrary number. But for discussion let's just use $1.25 per gallon. So let's say you'd haul a load and make adequate profit if fuel was at $1.25 and your line haul rate was $1.50 per mile. If fuel goes to $3.75 then USUALLY the fuel surcharge matrix would be .01 per mile fuel surcharge for every .05 increase in fuel. So at $3.75 you'd want to collect .50 per mile fuel surcharge to stay EVEN on your net fuel cost.
Now, reality is a little different. If your truck gets 6-7 miles to the gallon you could actually come out ahead if you were able to collect on 5 cent brackets for fuel surcharge. If you deadhead alot then you might get hosed. Also, as stated, brokers will try and screw you on fuel surcharge all the time and there are many different fuel surcharge programs in place - some based on percentage. I was just giving a simple example. Hope that answered your question.Another Canadian driver Thanks this. -
