what does it mean to pin wheel skids?
Discussion in 'Questions From New Drivers' started by Freebird135, May 13, 2009.
  1. Freebird135
    Freebird135 Road Train Member
    1,527
    906
    May 7, 2009
    In the air conditioning
    ive been working on loading docks for 3 years and have never heard this term til recently
    what does it mean exactly? just curious really
    i tried googling it by the way couldnt find anything
  3. 112racing
    112racing Road Train Member
    1,384
    20,548
    Nov 30, 2008
    pocono's, pa
    most pallets are 40"x 48" sometimes if the freight overhangs the pallets or a 96" wide trailer you must turn one of the pallets 90 degrees so the two will fit next to each other hence "pinweel" the pallet
    JReding and Baack Thank this.
  4. Freebird135
    1,527
    906
    May 7, 2009
    so its just running one straight in and the one next to is it turned sideways?
    JReding Thanks this.
  5. 25(2)+2
    18,749
    45,384
    Sep 18, 2006
    the road less travelled
    It is a way to fit more pallets in the same length more than width; pinwheeling puts the length of the pallet at roughly 40 inches instead of 48 inches, it is used to make 24 pallets fit side by side into a 48 foot trailer easily.
    The load may also be loaded that way so that the singles in a mostly double load are a bit shorter, getting slightly more weight per foot of length.
    A disadvantage of pinwheeled skids is that those skids must be either unloaded with with a regular forklift, meaning you must be at a loading dock, or you need to skid them to the back and, or turn them with a line or chain, a pallet jack can't get under them from the side.
    1 more thing, the pallet is structurally stronger with the boards running for and aft, rather than side to side, pinwheeling accomplishes that, the pallets must be 4 way pallets to do it.
  6. uncbenben
    uncbenben Bobtail Member
    45
    9
    Dec 23, 2008
    Aberdeen, MD
    I did this at a rite aid warehouse when I use to load outbound trailers, did it so I could fit all the applets and fit the hand jack at the end, I forget how many extra pallets you would get on a 53', but it sometimes was handy to do.
  7. Winchester Magnum
    Winchester Magnum Road Train Member
    1,492
    1,647
    Jan 4, 2009
    Alaska highway
    You can get a pallet jack in a sideways skid. I do it all the time. Works best if the sideways skid is up against the wall, but even if it's not, you can still get one leg of the jack under the skid, jack it up, and turn it a few degrees, then get both legs in.
    Most every load I do is chimneyblocked, and I have my own P jack with me at all times.
  8. 25(2)+2
    18,749
    45,384
    Sep 18, 2006
    Chimney blocked is easy compared to pulling a sideways single dead center with a large pallet jack, my companies have never provided us with one and the ones you get to use often should be in a museum or a junkpile.
    Seemed it was always a ton on a pallet in a 96 dry van on which the receiver specifically ordered them to not pinwheel any pallets.
    Probably the worst thing to get out is a liquid bulk container weighing 3000 lbs where the frame has collapsed,flat forks are no problem but you can't cram the jack into a hole that's not half high enough; time for a chain and some prayer that the thing survives the pull.
  9. Big Don
    Big Don "Old Fart"
    17,996
    35,643
    Sep 8, 2007
    Utah's DIXIE!
    Ah the joys of LTL. Glad I read this thread. It's just another reason I'm glad I'm retired now...:yes2557:
    25(2)+2 Thanks this.
  10. roadtime549
    roadtime549 Bobtail Member
    42
    6
    Jun 11, 2008
    FL
    I'm glad I quit pulling boxes and #*#*%$## reefers, food grade tanker now
