What does a DOT physical urine test for?
Discussion in 'Experienced Truckers' Advice' started by Trucks66, Aug 14, 2019.
  1. Trucks66
    Trucks66 Light Load Member
    189
    419
    Nov 3, 2017
  3. Chinatown
    Chinatown Road Train Member
    73,006
    163,634
    Aug 28, 2011
    Henderson, NV & Orient
  4. roshea
    roshea Road Train Member
    DOT urine test is just for sugar / diabetes, has nothing to do with any drug testing.
  5. ZVar
    ZVar Road Train Member
    10,911
    23,825
    Sep 10, 2010
    Flint, MI
    Which substances are tested?
    DOT drug tests require laboratory testing (49 CFR Part 40 Subpart F) for the following five classes of drugs:
    • Marijuana
    • Cocaine
    • Opiates – opium and codeine derivatives
    • Amphetamines and methamphetamines
    • Phencyclidine – PCP
    Drug cutoff concentrations can be found on the Substance Abuse and Mental Health Services Administration Web site.
    DOT alcohol tests identify alcohol concentration of 0.02 and greater.
    Tall Mike, Snoopycda and Chinatown Thank this.
  6. roshea
    Zvar that is correct but that has nothing to do with a DOT physical urine test. A DOT physical I'm sure you know does not conduct a DOT drug test, that is completely separate, and although it may be done concurrently it has no bearing on the conduct or outcome of a DOT physical.
    mitmaks, ZVar, tscottme and 2 others Thank this.
  7. Dave_in_AZ
    367,965
    Do you have sugar? I've no clue what the threshold is for passing/ failing.
    Some do it with a strip that changes color, I've had some inject it in a computercomp analyzer that does it to the ppm.
    That's all the actual DOT physical is though.
    The DOT drug test is a separate thing. And like has been stated, they may use the same sample for both, or do it separately.
    On the DOT drug test, they test for drugs.
    If you have any drugs, send them here care of TTR, and I will test them.
  8. Trucks66
    189
    419
    Nov 3, 2017
    Wait, so the urine tests for diabetes?
  9. yes it does..depending on how high of a sugar content do you have at the results and who does it some small mom-and-pop places may not go as far as some of the bigger places like Concentra...but if it shows up on the strip is higher they can make you go get an A1C test or notate that blood sugar is a little high but if it's in passing it's okay but if your blood sugar is not right then they can give you a 90-day pass just like with blood pressure until it's checked..
  10. Ubu
    Ubu Road Train Member
    1,252
    1,178
    Aug 25, 2012
    Rumored to be somewhere
    seamutt, Dave_in_AZ and roshea Thank this.
