what does a 1993 series 60 430hp need to make 550ish horsepower...
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Gambino1994, Aug 2, 2012.
  1. Gambino1994
    Gambino1994 Light Load Member
    187
    102
    Jan 22, 2009
    causing a situation
    This is a 12.7 litre i assume. Is it possible to get 500hp/1800tq with factory detroit parts? Did the ecm tunes go this far in 93?
  3. WMGUY
    WMGUY Road Train Member
    1,684
    800
    Jan 1, 2011
    Nine Mile Falls, WA
    i had a 98 12.7 and could be turned to 500hp 1800tq not as strong as the other engines but it is what it is
  4. Displaced Yooper
    Displaced Yooper Light Load Member
    152
    49
    Oct 18, 2010
    Detroit, MI
    In 1993 the ratings only went to 470HP (as per Wikipedia's entry on the Series 60). I'm not an expert, but if the engine is in good condition, I don't see 500+ w/ 1800TQ as a hard target to reach with just an ECM tune. PDI offers tunes for the DDEC III right on their website, and I know of a few tuners around the country that have them for the DDEC III as well.
    NWMAXI, your '98 was a DDEC IV, and those could do 500/1800 from the factory. DDEC III's didn't.
    NWMAXI Thanks this.
  5. Gambino1994
    187
    102
    Jan 22, 2009
    causing a situation
    Was there any differences in piston composition and cam profile between the early and late motors?
  6. Displaced Yooper
    152
    49
    Oct 18, 2010
    Detroit, MI
    Both the III's and the early IV's had 2-piece pistons w/ steel crowns. Later IV's (2003 & after) all have 1-piece steel pistons.
    Honestly not sure about the cam profiles, although with as many different part numbers there are for Series 60 cams,I'm sure there were differences.
  7. rebel127
    rebel127 Light Load Member
    296
    149
    Feb 28, 2011
    monroe ct
    There is minor differences in ddecII and III's pistons but a few cam profiles. There is only one commen ddecII cam I'm familiar with and a few ddecIII cams. A good upgrade for a ddecII is the cam.
    1958Pete Thanks this.
  8. Bush chook
    Bush chook Light Load Member
    144
    43
    Apr 27, 2009
    Geelong
    I agree with rebel cam and injector change will give you about 60 hp
  9. snapon2
    snapon2 Bobtail Member
    42
    8
    Jan 13, 2011
    grande prairie alberta
    A 1993 ddc s60 should be a ddec 2 if it still is, the best they came with that year was 450 hp @ 1450 tq..Custom ecm tuning can be set to whatever you desire.But as said if in good condtion 550 hp should hold up well .If you want to make 550 hp with parts only you will need injectors ,turbo and camshaft with the 450 aussie 0000 cert.hope this helps.
  10. snowwy
    snowwy Road Train Member
    20,527
    13,262
    Jul 6, 2009
    i'd go all out.
    bigger pistons and valves. cam. injectors. turbo. high flow muffler and straight manifold. no air filter. and a pdi tune.
    crank that baby up to 1000 horses.
    550 is too weak. :biggrin_25519:
