I guess this was bound to happen.. I sometimes like to push the limits of the theory of relativity.. I've been using my 7k aluminum car ramps to load all kinds of stuff. My theory is 7k ramps + 2x10's equals 10k... I figure 2x10 on top of 7k ramps is worth an extra 3k lbs..
I been meaning to get better ramps but I can never seem to make it up to Indiana to pick up a set. So I've been sticking my 2x10 on top of the ramps for quite a while and it tends to work ok.. Loaded all kinds of heavy trucks & vans.. It's usually ok anyway because even a 12k F550 isn't 12k on the ramps at once for example..
Well, I booked this RV that was paying $2/mile out of FL. I picked it up Thurs at a copart (self load) this way I'm loaded and can leave out Sat or Sunday and deliver Monday and I don't have to fight with the mad rush of everyone trying to book everything listed Monday morning after a holiday weekend..
So a few weeks ago I loaded an excavator that was 10k or so and I could tell it was pushing my advanced theory of relativity that calculated the weight rating of my ramps.. It loaded/unloaded but I was testing the theory for sure...
Fast forward to yesterday, instead of doubling Up the board /ramp I used the 2x10's for a kicker ramp because it's an RV and I needed the extra angle. It's supposed to be only 11k so sped across 2 axles should be fine I thought.. well... RV was running bad kept stalling and too much time on the ramp equals bent & cracked a ramp... sad face..
So I had to spend this morning 'fixing" my aluminum ramp with steel. I don't have any way to weld aluminum so I made some supports out of angle irons and flat bar then caged it all in place so it can't move. Should last until I finally get to Indiana and pick up some heavier duty ramps.
####ty-looking welds because I was just trying to do it fast but they will hold..
What do you do when you break your aluminum ramp in 2 on a holiday weekend..
Discussion in 'Expediter and Hot Shot Trucking Forum' started by crocky, Dec 31, 2021.
I don't think setting a 2x10 on top of the ramp is doing anything for you. Would you drive 3000lbs up just the 2x10?
Get some stabilizers to go under your ramps to help support the load. Big blocks would work -
Stabilizers don't work because if you, for instance, put wood blocks under the ramps the vehicle will push the back of the trailer down when the weight starts transferring to the trailer but the ramps don't move with it and they can come off the hook. The reason stabilizers work on step decks for instance is those types of ramps usually have a pin that holds it to the trailer so the ramp moves down with the trailer if the added weight starts compressing the springs when loading.
3k lbs on two 2x10's.. sure no problem so long as there is a way to secure the 2x10 so it doesn't move..
edit.... BTW I keep saying 2x10.. they are 2x12s and yeah they can actually hold a decent amount of weight. -
I know a welder that could fix that or build a better set in Cadillac MI , BUT again no location on Avatar.
crocky Thanks this. -
Leo Ingraham Welding
Cadillac , Mi or
Don Hunley @ www.gomra.com
Madison Heights , MILite bug Thanks this. -
Facebook link -
Wouldn’t that weight be dispersed somewhat through the entire board or a good part of it?
Sort of like concrete guys when they use boards to go over wet cement -
In fact, after the ramp broke, I put the 2x12 onto the ramp as I normally would for a heavy vehicle and drove it up using the 2x12 and put boards under it to support the broken part then loaded the RV on the broken ramp with the 2x12. The 2x12 held the weight of the RV at that point with the broken ramp under it so I could still attach it to the trailer.
Not that I'd like to do that again, but wood can actually hold a good amount of load if it's a good board.Last edited: Dec 31, 2021
GYPSY65 Thanks this.
