what do I need to consider when installing an Electric tarp systems on a dump truck
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Dwightsch, Mar 12, 2015.
  1. Dwightsch
    Dwightsch Bobtail Member
    14
    Im building a 98 mack ch brought a used dump bed that was damaged when it hit a bridge while raised. Cab protector was really only thing that was damaged . I had a new one made and I am getting ready to weld it on. when i get that done I have to install the electric tarp system. seeing how the cab protector is new What do I need to consider when installing the tarp reel As to where to locate it on the cab protector Forward to the front leading edge or high or Low on the back wall of the cab protector?? Im really considering high on the back wall Only problem is tarp motor will be real close to stacks. which would be best? advice Anyone?
  3. Dirty-Low-Walker
    Dirty-Low-Walker Medium Load Member
    359
    543
    Dec 17, 2013
    Try going on Mountaintarp.com
    They have several pictures showing different style tarp systems on dump bodies, trailers etc.
    Dwightsch Thanks this.
  4. Bout Z
    Bout Z Light Load Member
    275
    1,149
    Mar 14, 2015
    so. ohio
    Which type of electric tarp are you going to use? The flip tarp with the long arms on each side of the bed? Or the cable pulley type that slides across the top rail of the bed. Is the cab protector stepped, or even with the top of the bed?
  5. SL3406
    SL3406 Medium Load Member
    550
    1,482
    Jan 10, 2011
    Oklahoma
    I would mount it low on the back wall for two reasons. You need it low so the tarp will lay down on the load which prevents wind from getting under the tarp especially when driving in a cross wind. The second reason would be mounting it low gives it more protection from tree limbs when tailgating rock.
  6. Cetane+
    Cetane+ Road Train Member
    1,304
    882
    Sep 29, 2013
    Albany, NY
    Lets see, your putting a roll up tarp on a dump bed. So, will things get "dumped" into the box? Will you ever have mis shaped things dropped into it? Culvert pipes, tree stumps, rip rap, shot rock, bad operators taking out the side boards? Mount the roll as far forward as humanly possible. So they have to hit the front of your cab shield to bend the roll. Then figure if the arms are going to interfere with the doors, cab of the truck, if needed bend out of the way. See if the arms need to be bent to stay under the side boards when rolled up. Now figure if your tarp needs to cover your tailgate on top, here the state paving jobs require that. Now just measure from open position to covered position and weld the hinge / springs half way on the bottom of the side walls.
  7. Caterpillar Cowboy
    Caterpillar Cowboy Heavy Load Member
    837
    607
    Nov 11, 2010
    Wyoming
    All the manufacturers say to mount the arm pivot points high on the dump body, but don't mount it low, keeps them out of the way of your sloppier hoe operators. Also get the angled upper arm sections, same deal it keeps more parts out of harms way.
    The 'reel' as you call it should be mounted up against the headboard. I have mine sitting on the side rails of the bed up against the headboard. I've seen some other ways that people mount them they seem to get torn up less my way.
    I have, and have installed 2 pulltarps electric tarp systems on trucks. Like them, they hold up good, easy install and easy to get parts for. I like em.
    These are dump trucks, the world isn't perfect, some loads you'll get loaded and the tarp just won't work unless you have a chainsaw, cutting torch, etc. And also being in the world of dump trucks things are bound to get tore up at some point no matter what.
