What Chain length do most of you use on a 48' flatbed?
Discussion in 'Flatbed Trucking Forum' started by RERM, May 4, 2019.
  1. RERM
    RERM Road Train Member
    1,683
    1,124
    Dec 13, 2012
    Chicago, IL
    What chain length do most of you use?....this is for a 48' flat running general freight and steel.
    20ft or 25ft?
    jamespmack Thanks this.
  3. Kshaw0960
    Kshaw0960 Road Train Member
    1,581
    5,023
    Jun 17, 2018
    20ft is perfect. I have 12 chains.
    20ft let’s you use 1 chain for 2 tiedown points on most things and it’s long enough for big spools or anything else you come across. I’ve never once wanted longer chain and I’ve always had enough.
    jamespmack and booley Thank this.
  4. HoneyBadger67
    2,056
    4,511
    Dec 15, 2018
    Savannah, TN
    20 is plenty long enough. 16 should be long enough for steel and general freight. Longer sets are for when you're using one chain for multiple securement points.
  5. beastr123
    beastr123 Road Train Member
    2,803
    22,846
    Jan 2, 2014
    Moose Jaw SK CAN
    I carried 3X20' double grab hooks
    9X16' double grab hooks
    4X5' single grab hook
    4X5' 1 grab and 1 slip hook
    12 ratchet binders
    8 lever binders
  6. Cummins_444
    Cummins_444 Medium Load Member
    605
    1,014
    Apr 28, 2008
    Northwest, IN
    We carry six 20ft 3/8 chain and four 25ft 5/16 chain on our trucks.
  7. D.Tibbitt
    140,823
    Ive got 20 chains on my truck , all 5/16 and all 20ft ... I have ran into a problem a couple times where another 5 ft of chain wouldve helped.. I.e. a max 13'6 load with chain over the top of freight and freight stacked side by side , i have run out of chain by about a foot... Very very very rare that it happens.. Usually its i wish i had some shorter ones to make tie down a more effiecint process.. They dont cut easily like straps lol
    jamespmack, cke and booley Thank this.
  8. Ruthless
    Ruthless Road Train Member
    8,791
    86,000
    Aug 28, 2010
    The City.
    I don’t chain a whole lot, what products stack that tall that want chained vs strapped?
    jamespmack, cke, skellr and 2 others Thank this.
  9. booley
    booley Road Train Member
    1,408
    9,352
    Feb 16, 2008
    Some of our structural steel loads you would want to measure to make sure you'd fit under the bridges. Years ago, we had 5/16" 25', but in latter years I've just used 20' chain. We also got some nifty little 2 ft extensions for some of the bigger stuff.
    Straps are a heck of a lot easier to throw, but then you still gotta climb all over to put edge protectors in.
  10. D.Tibbitt
    140,823
    years ago. I hauled a load of these type of liftgates from southern cali up to a little fab shop in idaho falls, they had a bout 15 on the trailer.. I think they would put 5 side by side if i remeber correctly.. They bolt on a bracket on the top of the liftgate specifically for ur chains to go over.. I guess straps would work in theory , customer wanted chains so thats what i threw, long story short by the time my chain made it to the other side it was about a foot short... Nothing a binder and a pop up chain couldnt fix... Only time its ever happened to me. I think anything else like u said could be done with straps
    jamespmack, cke and Ruthless Thank this.
  11. Gumper
    Gumper Road Train Member
    1,533
    3,370
    Jan 7, 2018
    Butte, MT
    I have 20s and 16s. I’ve had a situation where the 16s weren’t long enough, so I’d say 20s are the best.
    jamespmack and cke Thank this.
