I have a brand new 2018 Cascadia with 18k miles on it. Twice in 4 days, I've had to bring it to a shop to have the lug nuts tightened on it. It has aluminum rims all the way around. What could be causing my lug nuts to keep coming loose?
What causes lug nuts to loosen up?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by #wishfulthinking, Aug 31, 2018.
Page 1 of 3
Inadequate torque on the re-torques
Temperature changes (expansion rate of steel and aluminum is different)
Since you say its new, wonder if the studs are stretching? Overtorqued maybe?magoo68, Justrucking2, aussiejosh and 6 others Thank this. -
Should be torque to 450 far as I know?
#wishfulthinking and Rideandrepair Thank this. -
Good job catching the problem.Once all are a little loose they snap causing disaster.Some claim previously over torqued and stretched lugs being properly torqued will loosen up. I wonder about this myself.With a new truck shouldn’t be your problem.If it’s on the same wheel 2 times Id be concerned. If it was the steers maybe they were removed during Transport then improperly re installed.I’m sure you had them check all 10 for proper torque. They have some safety products to keep them from moving also cheap plastic arrow shaped things that slip around lugs for an easy visual inspection for movement. Right now is the time to emphasize your concerns with Dealer. Make a little noise, maybe they can help with added cost or at minimum parts for cost and free labor to install. Emphasize the word Liability.
truckthatpassesyouby and #wishfulthinking Thank this. -
Torquing aluminum wheels is critical even on passenger vehicles. Here in Ontario you have to be certified to install a wheel on CMV or any vehicle at a commercial shop.
Justrucking2 and #wishfulthinking Thank this. -
Another thought:
If those wheels have been off recently the mounting surfaces may have gotten some mud or dirt trapped in between them and the hub?Justrucking2, pushbroom and #wishfulthinking Thank this. -
Lug nuts will loosen up sometimes.
Heat. Potholes. Cracks at 70 mph they will come loose.#wishfulthinking Thanks this. -
So, originally it was the left rear that was loose, today it was all but the right front drive, including the left rear, again.
If they are hub pilot, would too much thread lube keep them from staying tight?
tnpete and #wishfulthinking Thank this. -
Page 1 of 3
