What bushings for drive springs
Discussion in 'Trucks [ Eighteen Wheelers ]' started by paul 1052, Dec 21, 2011.
  1. paul 1052
    paul 1052 Heavy Load Member
    899
    346
    Oct 9, 2010
    Sand Springs, Ok.
    My 379 is going to get aligned soon and I'm going to have the spring bushings replaced too. The shop normally uses a urethane/rubber bushing but I'm leaning towards an all urethane bushing.
    What are the pros and cons for both?
  3. kustom
    kustom Light Load Member
    59
    25
    Aug 11, 2010
    coos bay, oregon
    Go with the horton roller bushings, you'll never go back.
  4. beltrans
    beltrans Medium Load Member
    441
    101
    Nov 26, 2008
    spokane wa
    Are they making bushings for rear suspension too?
  5. paul 1052
    899
    346
    Oct 9, 2010
    Sand Springs, Ok.
    Do they make them for the drives?
    The parts guy at Fargo Pete said they only make them for the steer axle.
  6. truckmechanic
    truckmechanic Medium Load Member
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    I like to use full poly bushings work on a fleet of mixers transfers,bellys,powder trucks and the poly hold up awesome on and off road use astro or energy suspension worth every penny
  7. Mr. Haney
    Mr. Haney Road Train Member
    2,693
    2,040
    Dec 17, 2008
    Dyco makes a set of polyurethane bushings for Peterbilt that you can't wear out. I've worn a set or the OEM style rubber center and urethane end bushings out in a year. I installed the Dyco's and have never worn them out
    http://www.propoly.com/aboutus/
    paul 1052 Thanks this.
  8. paul 1052
    899
    346
    Oct 9, 2010
    Sand Springs, Ok.
    Dyco it is, thanks.
  9. KW Parts Guy
    KW Parts Guy Light Load Member
    230
    78
    Jul 16, 2011
    These are for steers only, but hands down the best system out there. I have seen several gravel trucks do 10+ years on those.
