What are the secrets to a 15 spd...
Discussion in 'Experienced Truckers' Advice' started by 1989 Pete, Mar 27, 2008.
  1. 1989 Pete
    1989 Pete "Pine Tree Eater"
    i just found a project I like to restore 86 frieghtliner with a 425 cat 15sp...I never driven a 15 .Any pointers
  3. MickeyFIN
    MickeyFIN Light Load Member
    212
    6
    Mar 6, 2007
    Turku, Finland
    Move out of the way old timers...Wasn´t that how you stated a while back...
    And Now you ask them for help... Hmmm...
    So which way do you want it ?
    The secret is practice and watch your Rpm splits...
  4. Johnny99
    Johnny99 Johnny be Good
    549
    261
    Nov 24, 2007
    Big Sandy Tenn
    The only 15 spd I ever drove was actually a 10 spd with deep reduction on the low side. You could split the gears on the low side. Some of the drivers around here use them for pulling out of the gravel or sand pit loaded heavy, and some of the log trucks use them.
  5. kd5drx
    kd5drx <strong>Master of Electronic Communications</stron
    485
    102
    Nov 28, 2006
    Some where USA
    Depends on which type it is most of them were deep reduction 15's which like was said shift like a 10 with the option of splitting the bottom side for real deep reduction and starting real heavy loads off. The others shift like a 13 you split the top side for Overdrive and direct in each upper gear. So it all depends on the one you have in it.
  6. KCCW
    KCCW Bobtail Member
    29
    10
    Dec 31, 2007
    Littlefork, MN
    15 speed Roadangers are all RANGE type transmissions. LO range (deep reduction), LO & HI range. They shift like a straight 10 speed, you can't
    split anything. Some of the gears in deep & lo overlap so they're not a
    true 15 speed like a Mack triplex. Stop into a truck dealership and look at
    the rack of sales literature, there should be brochures on transmissions
    that show ratios, shift patterns etc.
    Oxbow Thanks this.
  7. Muleskinner
    Muleskinner <strong>"Shining Beacon of Chickenlights"</strong>
    :biggrin_25514::biggrin_25514::biggrin_25514:Mick's the man!!! I read his post and started to say the same thing and bless your heart....YOU BEAT ME TO IT...Pete make sure and wipe your mouth of with that do rag your so proud of after you eat your words.Don't you owe some "old timers" an apology over in another post????
  8. 1989 Pete
    Oh ok ok old timers you guys win lol...............nothing but love here.....keep trucking 10 -4 :biggrin_25520:
  9. 1989 Pete
    This 15spd has the deep reduction.........so thanks for the post!!!!
  10. Muleskinner
    10-4 back at ya....Eaton has vids and a lot of info on their site which saved me a nightmare a time or two.I don't have a link but its fairly easy to find.
  11. stranger
    stranger Road Train Member
    3,640
    4,959
    Oct 10, 2006
    NC
    Let an "old timer" help you out.
    A true 15 spd like you have has the deep reduction switch. On the older trucks it was a seperate switch mounted on the dash somewhere. I owned a Brockway (to see what a Brockway is go to the last picture in my photo albums) that had the switch mounted in the floor between the drivers seat and the door.
    The deep reduction is used when needing to move heavy loads on soft ground, taking off up steep hills, or any time you need to just creep and not take a chance of burning out a clutch or popping a driveshaft.
    When in deep reduction you can start in any of the five lower gears you want, but you can't go any higher than the fifth position without switching to low range.
    For example, lets say you started out in 1st gear, deep reduction. Shift on through the gears up to 5th. When you are at the speed or rpm that you need to change to the next gear from 5th deep reduction, reach up and switch the deep reduction out just before shifting while keeping the truck under acceleration.
    Instead of going back to the 1st gear position, go to the 4th gear position, as this is the next gear in the ratio sequence. Shift 4th and 5th low range as normal, select the high side from your shifter and go into 6th and shift the rest of the gears as you normally would.
    While in deep reduction you do not have to go all the way to 5th to make a progressive shift, or shift on the move. You can shift while moving from any gear but first. To to this you must always shift back one gear after leaving deep reduction. Examples are 1-2-3-move selector, 2-3-4-5, select high range, 6-7, and so on. Always drop back one gear when leaving deep reduction.
    If you want to have real fun, drive a 15 speed overdrive with a 9-10 turn around pattern. Your arm will move more directions than a break dancer caught in an electric fence.
