What are the risks of driving bobtail?
Discussion in 'Experienced Truckers' Advice' started by Goodykos, Dec 20, 2012.
  1. Goodykos
    Goodykos Light Load Member
    70
    205
    Aug 16, 2012
    What are the risks of driving bobtail. Notably in the rain, snow, ice and in windy conditions?
  3. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,214
    Sep 23, 2007
    Statesville, NC
    No weight on the drives, so when you try to stop you may skip. Remember the weight of the trailer is what is on the drives. No weight, less stopping power.
  4. DirtyBob
    DirtyBob Road Train Member
    1,913
    1,628
    Sep 2, 2010
    Indiana
    It's a lot easier to skid and lose traction in general due to the lack of weight. Just be easy on it in bad weather and give yourself plenty of room. Take turns easy. The wind has never really bothered me bobtail. There were nights when I was local running up and down Cajon I wouldn't bring a trailer home with me due to the wind and never had a problem bobtail.
  5. rank
    rank Road Train Member
    9,916
    113,498
    Feb 11, 2010
    imagine a 450 hp 2wd pickup truck only worse
  6. G/MAN
    G/MAN Road Train Member
    7,031
    8,621
    Sep 3, 2010
    Your drives could lock up and you could slide in wet road conditions. Never hit your brakes hard when bobtailing. Stay away from traffic and allow plenty of room between you and the vehicle in front of you.
  7. HuskerJim
    HuskerJim Light Load Member
    101
    61
    Nov 24, 2012
    Lincoln, NE
    Well, put it this way, last night in SE Nebraska, we were spinning the wheels taking off from a stop sign in a blizzard with 40,000 in the box.
    Dinomite and BoyWander Thank this.
  8. anytrucklldo
    anytrucklldo Bobtail Member
    16
    6
    Nov 18, 2012
    Like has been said the risk of locking up is greater as the brakes are designed for loaded axels more than for the light bobtail. The reason the truck will lock up easily is because as you brake the friction/traction between the road and the tyres increases (vehicle brakes 101) the same with the brake pad/shoe and the disc/drum the performance of the truck brakes is increased astronomically so in a low traction environment you will find the steer tyres will lock first and you will lose control and the momentum of the truck will keep it moving straight ahead and the stopping distance will be ridiculous also cornering you may find that the truck will under steer easily if you are in a single drive truck it will also over steer around corners with a bogie drive that risk is lesser but still a high possibility. Also the suspension is set up to carry weight and it rather stiff when bobtail so at speed the shock absorbers are working overtime to keep the wheels in contact with the road this along with poor road traction can also cause the truck to skip out and lose control.
    Unfortunatly your concentration level required is the same if not more than when hauling a load.
    alot o people will disagree but use the engine or exhaust brake to slow down even though your not heavy it will brake the truck but without the severe lock up an if it does compression lock the rear end at least your steer axel is not affected.
    But that's just my Experience and thoughts it's not gospel I hope it helps you
  9. TripleSix
    127,940
    In a nutshell, everything feels squirrelly in a bobtail. Steering, acceleration and braking for 80k at a fraction of the GVW. It's like everything else...you just have to be sure to take the time to adjust. Watch out for the jake.
  10. Dinomite
    Dinomite Road Train Member
    4,092
    4,308
    Sep 6, 2012
    Looking 4 Rocks
    Best thing about being in a bobtail you don't have to worry about a jack knife:)
  11. interdude
    interdude Light Load Member
    171
    74
    Mar 28, 2012
    when i took an air brake course decades ago, the instructor claimed that when the conditions are slick
    "there is nothing more dangerous to be around than a bobtailin cab"
    never seemed like a huge deal to me ..at all
