In California what dump truck is better to buy.
Triaxle,quad,tandem,transfer, end dump, etc??
What are the best types of dump trucks to buy in California?
Discussion in 'Questions From New Drivers' started by Regional, Apr 20, 2020.
Page 1 of 3
The best all around rig is a transfer but it takes good connections to keep one busy.
There are a lot of dump rigs in California and the rates haven't really kept pace with the times.
We have a couple of semi bottom dumps and end dumps but we use them mainly on our own jobs building logging roads.okiedokie Thanks this. -
You'll have to have a rig ready to go and it has to be reliable. If they call you for a job and you break down they probably won't call you any more. If you break down on a job they'll drag you off to one side out of the way and you're on your own.
You could try talking to contractors and rock companies on your own but, again, unless they know you and know you can perform you probably won't get very far.
Think this dump truck idea over before you commit. It's often seasonal work and there are always more trucks available than work for them to do. A long wet winter will absolutely kill you.
It's hard on equipment and if you're running in a rotation with a bunch of other trucks hauling by the ton the pace can be brutal.
The rates are terrible, again because there are so many trucks. We run our semi bottoms and end dumps mostly as a convenience for our own jobs. If we need some sets of doubles or transfers we can hire them for the day for not much more than it would cost to run our own equipment.
Why not get a job driving whatever kind of dump you plan on buying? Work for a season or two and you'll find a lot of your own answers to these questions.
With no background in dump work and no connections I'd be hesitant to even try it.okiedokie and Western flyer Thank this. -
Here you go, I’ve seen a couple of these running around on the 91.
It’s got a sleeper on it so in case you get tired you can take a nap. -
Can you have more then 2 axles in CA?
BigDog Trucker, Western flyer and Bakerman Thank this.
What kind of dump truck are you guys calling transfers........? Like a live floor garbage trailer...?
I don’t get out much.... -
Page 1 of 3
