What are some engines to avoid not matter what.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Colorato, Dec 10, 2012.
  1. Colorato
    Colorato Road Train Member
    1,336
    865
    Feb 22, 2011
    In the next 16 months I plan to get my own truck. I've been working on getting my financial house together and get some money saved back. I'm trying to get as much info on all aspects of being an O/O in that time frame.
    When it comes to trucks one of the things I've been looking at is pre-EGR engines. I'm looking at my first truck being in the 20-25K range. I'm somewhat familiar with some of the engines but not all. From your experience what is a engine to avoid? Reasons from reliability, high maintenance, and poor fuel economy are just a few examples of what I'm after.
    Thanks.
  3. allan5oh
    allan5oh Road Train Member
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    Any 95-03 engine will be better than any post 2004 engine. That being said the older engines aren't perfect by any means. Detroits had bullgear problems, c12 cats had head gasket problems etc..
    Cats are known to get a little worse fuel mileage than the others.
    From a purely economic standpoint, the DDC3 and DDC4 detroits are hard to beat.
    Colorato Thanks this.
  4. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,766
    Mar 5, 2012
    Ontario Canada
    Mine may not qualify because you are looking for pre EGR. But here it is. The caterpillar SDP series engines are probably the worst they ever put out. The DPF will cost you $5k to remove, then you have emissions cops issues. The MPG I am averaging is 5.7. That is after I had a full warranty rebuild including new CAC and DPF. They said they had never seen an engine with so much soot through it before. I consider myself VERY lucky with mine because the aftermarket DPF they put on actually functions the way it should. Mind you, I have to keep the RPM at 1400 and not work it very hard for extended periods of time or else it won't initiate a cook cycle properly. The engine needs to put out 550 horse for the DPF to properly work. When the CEL comes on it de-rates the power. This will, if you let it go, eventually destroy the DPF and you will need cat to come out and fix it for you, on the side of the road. It is just a heck of a lot of headaches. Before I had the rebuild it averaged 4 mpg. I installed a fuel wire after the rebuild and also 5 axles of MB wheel bearings. The bearings got me the .7 and the fuel wire gets me something like 1/4. I am looking forward to the day this truck is paid off, but I don't expect it to last much longer after I make the final payment.
    Happy trucking.
    Colorato and buddyvuk Thank this.
  5. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    stay away from exotic Paccar MX (DAF105, Pete, KW), and avoid MAN D20 series engines (Maxxforce)....
  6. freightlinerman
    freightlinerman Road Train Member
    1,287
    536
    Mar 4, 2011
    Florida
    Easy, get a Series 60 or an N14 Cummins.
    MNdriver, x#1 and Colorato Thank this.
  7. WitchingHour
    WitchingHour Road Train Member
    3,424
    2,143
    Apr 1, 2011
    Broomfield, CO
    Avoid, like something that'll give you AIDS, the Volvo D16. In fact, it just might be able to give you AIDS. Whether it can or can't, you don't want it. Sure, that 16.1 liters gives you plenty of brunt... when it's functioning properly. And there lies your problem.
  8. Colorato
    1,336
    865
    Feb 22, 2011
    Those are the 2 I have been focusing on more. I just don't know much about the N14.
  9. Colorato
    1,336
    865
    Feb 22, 2011
    Both the Volvo engines and Mack's are not even a option to me. Thanks.
  10. WitchingHour
    3,424
    2,143
    Apr 1, 2011
    Broomfield, CO
    Pretty solid motor. 14 liters even, good reputation behind it. Celect was what they called them once they went electronic, Celect Plus was the electronics package from 97 onwards, IIRC. Great for beating through the mountains with a set of 3.73s, still substantial enough to turn 3.55s. I believe the red tops were available in up to 500 hp, though 435 or 460 seems more commonplace (but that can be rectified easily enough).
  11. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    Yep, D16 was made for heavy haulers and no reason to own FH16 truck if you tow regular trailer. All parts are too expencive
    But I cant say the same about Merceds 16L engine (OM502LE). Becouse it is just enlarged to 8 cylinders regular engine. Pistons, bearings and other parts are the same.
