I have no APU and I am death scared to idle my truck with this def system on it. I would love to buy a brand new APU but todays rates makes those prices seem like a deep dig, u know blah blah blah lol. Any and all advice is greatly appreciated.
What are some APU alternative setups??? its getting hot!!!
Discussion in 'Ask An Owner Operator' started by FreezingHot32, Apr 6, 2023.
Page 1 of 8
KB3MMX, austinmike and Chinatown Thank this.
Get a used one. Thermo King has them advertised for $5000. Lots more on Truck Paper. All the brands from $3500-$5500. Google Refurbished APU. There are companies that specialize in this.
mitmaks, FreezingHot32, KB3MMX and 2 others Thank this. -
I think there is a place out of the Springfield/Joplin Missouri area that specializes in used APU installs. Sorry I don't recall the name.
Alternatively, buy a predator generator from harbor freight with that warranty they offer and hook something up yourself.FreezingHot32 and KB3MMX Thank this. -
Harbor freight generator and a portable ac, start generator and stick the hose out the window
flood, bamanation, LoneRanger and 2 others Thank this. -
My green has more hours on it then the thermocrap and no a single issue so far save 1 recall item they literally had fixed in the time it took me to buy an oil change kit. So far its worked as high as 95 degrees where i woke up with the cab at 55 inside (something my thermocrap could not do btw it couldnt keep 90 degrees under 75 inside and 110 was 80+ which thermokunt said was normal) and as low as -40 with wind chill down to -60 where it kept stuff at a comfy 65 inside. Again something my thermocrap could not do. It wouldnt even keep the inside at 40 degrees.
$13,000 but they will do payments for you and they are quite reasonable. Comes with a 3000 HOUR <not mile derp> warranty and everything save the controler is off the shelf parts you can get at ANY farm and home or auto zone. Uses a bit more fuel then a thermocrap but better in every other way so far.
And yes im still pissed at thermocrap lol.RockinChair, Rideandrepair, Siinman and 2 others Thank this. -
RockinChair, LoneRanger, Siinman and 3 others Thank this.
I hate APUs. They don’t provide enough cooling in the southwest and would constantly overheat. If you don’t go to those areas you are probably ok. I would idle or do the generator AC thing.
The Railsplitter and FreezingHot32 Thank this. -
An RV center can install one like is used on large RV's. I've seen a few trucks with those and they look good.
RubyEagle, Siinman, FreezingHot32 and 1 other person Thank this.
Page 1 of 8
