What are my options now with a bad egr valve
Discussion in 'Volvo Forum' started by poniikyanion, Jun 28, 2014.
  1. poniikyanion
    poniikyanion Light Load Member
    69
    14
    Nov 23, 2009
    Newark, NJ
    I have a 2005 with a d12d 630k mile. So two months ago my number 2 egr valve finally out. I got smoke shooting out of the stack after warm up and faults and check engine light.
    My question is simple. What is the cost of replacing both valves?
  3. poniikyanion
    69
    14
    Nov 23, 2009
    Newark, NJ
    They won't turn off the check engine light and solve the derate problem.
  4. MJ1657
    MJ1657 Road Train Member
    7,521
    50,150
    Jan 28, 2012
    Isanti, MN
    I don't think you can talk about that kind of stuff anymore.
    d o g Thanks this.
  5. cabwrecker
    cabwrecker The clutch wrecker
    1,626
    1,423
    Mar 23, 2012
    Correct me if I'm wrong, which is a typically situation. But isn't the EGR valve replacement absolutely necessary to keep whatever engine, OP is using, running?
    Kind sad we can't figure out a way to get emissions lower without using something like an EGR, but hey- there you have it.
  6. MJ1657
    7,521
    50,150
    Jan 28, 2012
    Isanti, MN
    I should have been more clear. You can talk about replacing it but I don't think you can talk about deleting it because its emission systems modification.
    cabwrecker and d o g Thank this.
  7. cabwrecker
    1,626
    1,423
    Mar 23, 2012
    And modifying/pulling out the emissions systems on the newer models is like trying to change Hezbollah's mind about Israel, correct?
    Just trying to pickup some information here. Fairly sure I know the answer, would love to have it confirmed.
  8. MJ1657
    7,521
    50,150
    Jan 28, 2012
    Isanti, MN
    I'm not trying to piss anyone off. As you see any emissions modification posts get deleted. Sucks but thats what happens.
    d o g Thanks this.
  9. Gadget
    Gadget Bobtail Member
    9
    Aug 10, 2013
    Port Deposit, MD
    It doesn't seem to to me as if the op is asking about deleting. He asked how much to replace the valves that to me is necessary repairs.
  10. Moneymike
    Moneymike Light Load Member
    118
    31
    Apr 17, 2013
    About 2800 to replace or $7 to block off.
    Johny41 and poppapump1332 Thank this.
  11. cabwrecker
    1,626
    1,423
    Mar 23, 2012
    Well I was a bit confused.
    After a very short period of digging around, I found this.
    Makes sense, when you give consideration to the fact that this is one of the most active drivers forums on the internet.
    Can't blame 'em.
    MJ1657 Thanks this.
