What advantage if any running 24.5 on steer and 22.5 on drive?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by bowtieboy77, Feb 17, 2014.
  1. bowtieboy77
    bowtieboy77 Light Load Member
    274
    82
    Aug 16, 2013
    Southern, Ontario
    I saw a post about mismatched tires down below and caused me to remember this question. The first shop I worked at when I first started wrenching (15yrs ago now) the boss also owned highway tractors. I always wondered and maybe theres no advantage to it but he always ran 24.5 on steer and 22.5 on drives? Has anyone seen this done and is there any advantages in doing so I have never seen anyone do it since so I'm thinking it was a crazy thought he had that made sense to him and him only.
  3. that65
    that65 Light Load Member
    185
    84
    Jan 16, 2012
    Lincoln,Ne.
    yes, it will run faster, with better mpg................
  4. bobbyhill
    bobbyhill Light Load Member
    168
    151
    Aug 13, 2007
    Left Lane
    I run big rubber in the front because it fills my fenders hated the look of 22.5s in there
  5. russtrucker
    russtrucker Road Train Member
    1,767
    337
    Mar 27, 2012
    Central PA
    I'm fine with my 24.5 from hitting mud with my side fairings.
  6. rollin coal
    rollin coal Road Train Member
    13,080
    25,855
    Mar 29, 2008
    TN
    Like somebody said in another thread, probably got a great deal on 8 drives that mismatched the steers or vice versa. Otherwise it just seems like more hassle having mismatched hodgepodge on a piece of equipment. Can't really fathom some reason it would be beneficial but have heard stranger things before and would try to understand...
  7. russtrucker
    1,767
    337
    Mar 27, 2012
    Central PA
    I would use 22.5 for on-highway. Right now, used for frac sand.
  8. Exiled
    Exiled Light Load Member
    181
    29
    Apr 20, 2013
    I once replaced 295/75r22.5 with 315/80r22.5 (About a 1 inch wider, 3 inches taller)
    the big difference is a smoother ride on rough roads and looks better too i think
  9. freightlinerman
    freightlinerman Road Train Member
    1,287
    536
    Mar 4, 2011
    Florida
    I can tell you the 11R24.5 ride sooo much better than low pro rubber. Plus, I'm guessing they would last longer, since they are taller and less revolutions.
  10. russtrucker
    1,767
    337
    Mar 27, 2012
    Central PA
    Mine are 285/75R/24.5. I use Kelly Tires. So Far so good. Goodyear and firestone still do make those tires with that size.
  11. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,044
    May 13, 2011
    Middle Tennessee
    You could even take an inch out of the spacers on the front axle to lower it to keep truck level if going to smaller size on rears.
