Wet weather winter glove recommendation.
Discussion in 'Canadian Truckers Forum' started by upnorthwpg, Nov 20, 2022.
  1. upnorthwpg
    upnorthwpg Road Train Member
    1,716
    2,459
    Sep 23, 2011
    Need some ideas on wet weather winter gloves. I’m good on the dock as I run heated glove liners, and have a good pair of insulated gloves for dry cold weather. My issue is hooking and breaking sets in the slop. What do the fuel guys or the rig workers use?
    austinmike Thanks this.
  3. Numb
    Numb Crusty Curmudgeon
    3,938
    8,760
    Jan 30, 2012
    Charlotte, N.Carolina
    good pair of ski gloves.
  4. upnorthwpg
    1,716
    2,459
    Sep 23, 2011
    Not waterproof and get torn easy.
    nredfor88 and austinmike Thank this.
  5. austinmike
    86,156
    It's hard to get a really good pair of gloves that function and fit the way you want them to. I've tried all different kinds.
    Seems like the main thing is to have at least 2 maybe three pairs on hand at all times so you can switch em out when they get wet.
  6. GYPSY65
    GYPSY65 Road Train Member
    1,956
    5,263
    Nov 16, 2012
    SW FLA
    I use a good pair of leather gloves with the brown cloth gloves as inserts
    I also seal my leather gloves
  7. Albertaflatbed
    Albertaflatbed Medium Load Member
    332
    856
    Nov 20, 2022
    Nisku, AB
    I use full grain leather gloves, always have several pairs. Once a pair gets too wet for comfort I through the on the dash or floor under the heat vents to dry out and switch to the next pair.
    Goodysnap, nredfor88 and austinmike Thank this.
  8. Short Fuse EOD
    2,745
    8,521
    Jul 29, 2015
    Midwest
    Wells Lamont 867
    Insulated waterproof palm made for work
    Also not overpriced, will need two pairs or a glove dryer overnight
    Tall Mike and upnorthwpg Thank this.
  9. MSQUARED
    MSQUARED Medium Load Member
    334
    484
    Mar 28, 2021
    Those Holmes leather gloves from Costco are actually pretty good. The don't turn your hands yellow like most yellow leather pairs
    Elroythekid Thanks this.
  10. BigHossVolvo
    BigHossVolvo Road Train Member
    1,516
    2,284
    Dec 15, 2016
    Calgary, Alberta
    Tall Mike, tinytim and '88K100 Thank this.
  11. upnorthwpg
    1,716
    2,459
    Sep 23, 2011
    I have the first two. I like the red barons because of the wide cuff. I found a pair of insulated double dipped wet weather gloves that worked good in the slop this morning. Crappy thing is they will tear on the rusty crank handles, but I’ll run with these for now. Thanks guys.
    BigHossVolvo and '88K100 Thank this.
