Hi everyone, I heard someone talking about a wet vs dry maintenance package for their rig, and wondered what they were referring to ("wet" meaning it includes regular scheduled fluid replacement, and dry meaning without?)
We have a new Kenworth straight truck, but we don't want to get hosed on the maintenance program. Any advice on selecting maintenance programs with a dealer in general?
Wet vs Dry maintenance packages
Discussion in 'Experienced Truckers' Advice' started by JR981, May 14, 2010.
Here is some misc. info that I found:
Premium Preventive Maintenance - $254.99*
This preventive maintenance package includes up to 44 quarts of oil, up to 3 filters, and DOT inspection
- On-Site oil sample analysis
- Check differential oil
- Check transmission oil
- Check coolant level, freeze point, and nitrite level
- Install oil/fuel filters and tighten
- Drain plug torqued to engine mfg specs
- Fill with oil to proper level
- Install/tighten oil cap
- Start engine, check for leaks
- Lube fifth wheel, chassis, drive train
- Check oil level in steering hubs
- Check power steering fluid
- Inspect drive shaft/U-joints
- Inspect brake lining thickness
- Check/air-up tires to recommended PSI
- Inspect all hoses & belts
- Check all lights
- Check hood latch for closure
- Complete DOT Inspection
- Check all lights
Complete Preventive Maintenance - $219.99*
This preventive maintenance package includes up to 44 quarts of oil and up to 3 filters.
- Check coolant level, freeze point, and condition
- Check all lights
Express Preventive Maintenance - $204.99*
- Check engine coolant level, freeze point, and condition
Basic Preventive Maintenance - $179.99*
This preventive maintenance package includes up to 44 quarts of oil and up to 2 filters.
- Install up to 2 oil/fuel filters
This preventive maintenance package includes up to 1 gallon of oil (not synthetics) and 1 fuel filter.
- Check coolant level, conditioner, and freeze point
- Check hub oil
- Change fuel filter
- Check brake lining thickness
- Wheel ends for leakage
- Air bags
- Hub oil
- Lights
- Glad Hands
- Conspicuity tape
- Mud flaps/hangers
- Springs/hangers/shocks
- 5th wheel pin/mounting plate
- Air leaks
- Lube trailer
- Adjust brakes
- Doors/hinges
- Floor
- Sides
- Landing Gear
Working Class Patriot Thanks this. -
i don't know much about trucks, but it seems like you could do all that yourself?
We're not talking quarts here....We're talking gallons....
You can't toss away used oil, fuel, and coolant filters either in your trash can...They're all hazardous waste....
Hell...I could service my rig in front of my house...but the next door neighbor would call the PD out and have me arrested......
You're not even supposed to work on your own POV out in the open..in my neighborhood now.... -
Texas and country living is calling your name.
Then you could run to Cali and back.......you're all set up for it now anyway.Working Class Patriot Thanks this. -
And the dry maintenance sounds like bull. You could do all of the dry maintenance package yourself. It's a pre-trip inspection and a gallon of oil and a fuel filter!
As for used oil, you could sneak it out to autozone...they'll let you take oil to recycle for free. I mean, like a couple gallons. There's atleast 5 or 6 autozones in my area, and they do not keep records of who brings it in......and its pretty common for people to find small industrial drums (im talking about like the 4 gallon kind) to save the oil in and take it in there....
But as for a full oil change, screw it. Do you even have a jack big enough to jack the truck up? -
It's my property. I'll park what I want, where I want, and work on it if I want...and there ain't a dang thing anyone else can do about it. They don't pay my mortgage. They don't pay my property tax. They have no say in what I do on or with my property.Hott Rodd Thanks this. -
Changing the oil on a semi isn't any harder than changing the oil on a car. In fact, it's EASIER!!! I can change the oil on my Mack without ever even putting a knee down on the ground. To change the oil in a car, you are on your back to get at the drain plug. Biggest obstacle you may have is finding a large enough drain pan to hold all of the oil. If I ever get around to welding it up, I have the stuff to make one. Until the, I use 2...fill one part ways, then slide it out as I slide the other one into the stream.
And yes, I have a few jacks that will do anything I need them to. I used a high-lift jack to change a rear airbag on the tractor. I've used a 6 ton bottle jack to grease the king pins. I've used a 20 ton bottle jack to rotate/change my tires. I've used a 2-ton engine hoist to break stubborn lug nuts loose when my 3/4" gun wasn't getting the job done.
It's all just nuts & bolts. Nuthin' ta be skeerd of. -
I get a laugh out of #8 & 18- "Install/tighten filer cap"- "Check Hood latch for closure". Well that seals the deal for me!
I say if you have a place to do it, all this can be done yourself. If you can't find someone to take your used oil, take it to an Auto Zone or some such place they will take it.
The oil analysis is worth getting done however. -
