Wet lumber under tarps
Discussion in 'Flatbed Trucking Forum' started by Curly88, Oct 9, 2018.
  1. Curly88
    Curly88 Light Load Member
    180
    227
    May 16, 2012
    Rexford Mt
    Couple questions on tarps. First of all I unloaded a tarped lumber load after driving thru rain for a day and a half and saw a few very big wet splotches on the sides of the load. I know the tarps have a few small holes from the bungees but I never figured that much water would come thru. Also when I parked for the night I made sure the trailer was downhill. The forklift guy never said anything so I didn't either. 'Plywood' Have any of you guys had tapped loads get wet? And did the customer say anything?
    Second question, I see guys tarp loads all the time with the tarps being 6" short on the sides or a ft or 2 short in the end. How do they get by with that? 'Not talking about vegetable loads either' thanks
    cke Thanks this.
  3. pmdriver
    pmdriver Road Train Member
    2,338
    3,503
    Nov 14, 2017
    Look at what most lumber yards do with the lumber, it is sitting out in the weather and when you buy it you have to dry it out as a customer and try not let the warping begin. At least around here it is that way.
    Lepton1, beastr123, cke and 1 other person Thank this.
  4. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
    You aint going to see lumber yards scrambling to bring in stacks of wood in a rain.
    Eventually if plywood is your goal in a store as a customer, pick the good ones.
    Curly88 Thanks this.
  5. rcelmo
    rcelmo Medium Load Member
    459
    1,986
    Mar 23, 2015
    I used to work for a flatbed company......their policy was if the
    customer asks for a tarp but refuses to pay extra for it...…..the tarp
    job was not done to well. If the customer wants a top level tarp job they
    have to pay for it. Not saying that is the right way but they did have a point......
    Paddlewagon and Curly88 Thank this.
  6. Pedigreed Bulldog
    7,737
    14,421
    May 7, 2011
    Always fun when it's pouring down rain, they load you outside, taking their time to get it all on there, and the entire load is thoroughly soaked by the time they're done putting it on your trailer.
    Then, they point you over to a covered area to tarp it.
    I guess that beat tarping it in the rain...but still seemed rather pointless.
  7. thelushlarry
    thelushlarry Road Train Member
    3,023
    8,997
    Jan 9, 2012
    glasgow ky
    The tarp is to keep the sun from drying it out!
    Badmon and PoleCrusher Thank this.
  8. Paddlewagon
    Paddlewagon Light Load Member
    278
    264
    Sep 17, 2017
    Llano Estacado
    I actually had a load of lumber rejected once because it was too wet.........Forklift driver came over after I had untarped and jammed a "moisture meter" into the wood and declared it to be too wet and he wasn't accepting the load.:eek::mad:
    NavigatorWife, PoleCrusher and Curly88 Thank this.
  9. REO6205
    REO6205 Road Train Member
    13,172
    60,483
    Feb 15, 2014
    California.
    It depends on what kind of lumber you'te hauling. If it's kiln dried pine, quarter sawn, and surfaced on all four sides you better not have any wet boards. Same with vertical grain Doug Fir. No water on the load.
    Same with finished moulding. That stuff is expensive and usually gets tarped regardless of weather. LOL...nothing like tarping in August, in the Sacramento Valley, on asphalt that's been soaking up heat all day long, to make you wish you'd taken that tanker job when you had a chance.
    If you're hauling construction grade lumber and it has to be tarped a few water spots here and there aren't usually a big deal.
    I used to haul out of a mill that cut cedar fencing and siding. Didn't matter that the stuff was going to be used outside, it had to be tarped. I see now that the mill wraps the units in white plastic instead.
  10. Gumper
    Gumper Road Train Member
    1,536
    3,389
    Jan 7, 2018
    Butte, MT
    If they didn’t say anything when it was getting unloaded then get the papers signed, and GTFO of there. Once it’s off, and the signatures are on it’s no longer your problem :D
    Lepton1, Grubby, NavigatorWife and 2 others Thank this.
  11. Boardhauler
    Boardhauler Road Train Member
    1,688
    3,191
    Dec 21, 2008
    Ballin' in it for Shakey
    [QUOTE="REO6205, post: 7984329, member: 137130"
    I used to haul out of a mill that cut cedar fencing and siding. Didn't matter that the stuff was going to be used outside, it had to be tarped. I see now that the mill wraps the units in white plastic instead.[/QUOTE]
    Oroville?
