Western Star clutch? Will not go into gear without jamming it!
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Perchie15, Jun 16, 2024.
  1. Perchie15
    Perchie15 Light Load Member
    235
    70
    Aug 16, 2021
    I’ve done all the adjustments 1/2” and 1/8” but the truck still does not want to go into gear, it eventually does when u ram it and when u get it into gear it like wants to hold it in gear then you gotta force it out, and when the clutch brake is being held it still wants to spin on the shaft. So what could be causing this? TIA
  3. Big Road Skateboard
    6,183
    33,956
    May 2, 2021
    Did you try spinning the clutch brake by hand? While underneath setting the presdure plate.
    How much free travel in the pedal?
  4. Perchie15
    235
    70
    Aug 16, 2021
    2.5” yea I can’t spin it by hand or pry bar either.
    Big Road Skateboard Thanks this.
  5. Big Road Skateboard
    6,183
    33,956
    May 2, 2021
    Ok. Lose about an inch of that free travel with the linkage. You need more pedal. See what happens
    Deere hunter Thanks this.
  6. Perchie15
    235
    70
    Aug 16, 2021
  7. Big Road Skateboard
    6,183
    33,956
    May 2, 2021
    You had 1.5" before the adjustment? Or before a new clutch brake?
  8. ElmerFudpucker
    4,979
    54,269
    May 17, 2024
    Is this a solo clutch?
  9. Goodysnap
    Goodysnap Road Train Member
    3,717
    9,024
    Jul 12, 2017
    Sounds like the clutch is not fully releasing. Most likely dragging due to a broken dampening spring.
  10. Deere hunter
    2,018
    9,100
    Aug 5, 2017
    Shallowater Texas
    Yeah, I was gonna say one of your center plates is hanging up for some reason. Either in your flywheel dogs or your spine or you have a plate spring wedged in there.
    ElmerFudpucker Thanks this.
  11. Perchie15
    235
    70
    Aug 16, 2021
    I’m not even sure what that is. But I googled it and no it doesn’t have any kind of indicator where it shows to put it new of wear etc..
