Western Star Car Carriers
Discussion in 'Car Hauler and Auto Carrier Trucking Forum' started by Transfury, Jan 4, 2013.
  1. Transfury
    Transfury Bobtail Member
    8
    Dec 26, 2012
    Ive been trying to find some more info on the Western Star 4900's Lowmax's and i cant really get any info on them. What i did find was that brand new they run about 224,000 and used i could pick one up for around 130,000. Anyone have any experience with these trucks? Why are they so much cheaper than the Peterbitls or the Volvos? Any help would be greatly appreciated!
  3. Transfury
    8
    Dec 26, 2012
    Thanks for all the quick responses... lol... anyways i did some research and i found out that the western star cabins are a little shorter in height than the peterbilts. Also found out that they are all custom order made (though im not sure about that) Many people said that they are pretty much the same quality and dependability as the peterbilts. In fact some people claim they never break down because "you dont see any Western Stars at the body shop". Finally i found that the interior has 3 different options -> the cheap one that sucks, and two higher that are good. If you get the cheap on the truck is going to be loud in the cabin and cold.
    Other than that, it seems like im leaning towards the western star.
  4. KANSAS TRANSIT
    KANSAS TRANSIT Road Train Member
    4,080
    6,842
    Jul 28, 2011
    Glasco,Ks.
    I would also guess that depending on what model Pete you are looking at, for instance, that WS CH has an overall cab height of 101" from the factory, the ONLY way a Pete gets close to that low is if you do a Fontaine cab chop or buy one of those WCT lowered frame section Pete 365, they are not cheap.
    I have not priced the new Volvo WAH's so I'm not sure what they run, but I believe they will get you in that WS range on cab height.
    ALSO, one BIG advantage of the WS is IF you are not going to run Cali. you CAN order a WS CH as a glider, order it with a 500hp Cummins N-14 or series 60 right from the factory, add your choice of tranny and rear and you would have a great combo.
    Yes, you can order the Pete now as a glider, but to try and spec it as a low pro would probably be a PITA, I really don't think that Pete and KW's glider program is as well thought out as Freightliner/WS is.
    JMHO
    Stan
  5. KustomTruck
    KustomTruck Bobtail Member
    38
    55
    Oct 3, 2012
    Coos Bay, OR
    Western Star and Freightliner trucks are still a Non-Multiplex cab configuration. Both Kenworth and Peterbilt use Multiplex cab architecture. Basically WS/FL build their cab around the engine electronics and KW/Pete build their cab and tell the consumer if they want to install an engine that operates on a different generation of electronics ... your on your own. WS also does offer a more complete glider kit package, ex. the piping kits are supplied and correct for the engine, the engine control harness is plug and play, all hoses are supplied, ect. You can achieve the same end result out of a Pete or KW, it just takes more insight and forethought to do it as efficiently as what WS/FL offer in their glider programs.
    cisco and Pullin2 Thank this.
