West Virginia drivers
Discussion in 'Experienced Truckers' Advice' started by STR8STAKZ, May 7, 2018.
  1. STR8STAKZ
    STR8STAKZ Bobtail Member
    34
    44
    Mar 6, 2014
    Got a load going to Elkins WV tomorrow. From my location I can take 33 or 250 from 81. Ive been on 33 emty was less than thrilling. Can't imagine doing with 45k behind my ###. So which is the lesser of the 2 evils? 33 or 250
  3. Grouch
    Grouch Road Train Member
    2,079
    4,243
    Feb 3, 2009
    Between here and eternity
    33 is your best route. 250 when you leave Staunton Va is "rough". Where are you coming from?
  4. Hurst
    Hurst Registered Member
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    Personally I'd rather have my FLHT on route 33,..
    But I'll just leave these here.
    Doable yes,.. dangerous and potentially deadly? Absolutely.
    Hurst
  5. STR8STAKZ
    34
    44
    Mar 6, 2014
    Coming from Raleigh NC. Probably go up 86 into VA and hit 29 to 64 over to 81
    Lepton1 and OLDSKOOLERnWV Thank this.
  6. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
    Settle in. Enjoy the ride. It'll be a while. Treat the hills with respect always. And you will be fine.
    KB3MMX Thanks this.
  7. MACK E-6
    48,113
    219,511
    TripleSix and OLDSKOOLERnWV Thank this.
  8. OLDSKOOLERnWV
    17,804
    268,363
    33 probably the best of the 2 roads.
    Me.... I'd probably run I-77 up to Beckley WV and jump on 19 North, that dumps you out on I-79 at exit 57. Jump off exit 99 and boogie in from that way. I've ran 33 loaded with lumber before, be like the Oregon trail :).
    ncmickey, Lepton1, Roguefox and 3 others Thank this.
  9. OLDSKOOLERnWV
    17,804
    268,363
    And 19 is 4 lane too, takes ya across the New river Gorge bridge.
    Lepton1, x1Heavy, TripleSix and 2 others Thank this.
  10. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,056
    Nov 18, 2014
    Land of local
    Either way prepare for them hills. I've never been on us 250 in wv, only Ohio but I have been on 19&119 pretty hilly in some spots
  11. STR8STAKZ
    34
    44
    Mar 6, 2014
    33 it's going to be. Got to pull in Harrisonburg truck stop and stock up on those fried pies first.
    OLDSKOOLERnWV Thanks this.
