Werner fleet sales
Discussion in 'Freightliner Forum' started by AlexD13, Dec 17, 2020.
  1. AlexD13
    AlexD13 Light Load Member
    298
    85
    Jun 13, 2016
    Hello All, Wondering if anyone has purchased from Werner direct. they have a 17 Cascadia 400k miles for $64k. There is another dealer nearby 16 Cascadia with 440k miles for $49k. Wanted to see others’ perspective on is it worth paying 15k more for the werner truck?
    truckdriver31 Thanks this.
  3. Chinatown
    Chinatown Road Train Member
    73,251
    164,564
    Aug 28, 2011
    Henderson, NV & Orient
  4. tallguy66
    tallguy66 Medium Load Member
    534
    873
    Oct 18, 2018
    I don’t have any real good input here but I would like to mention that it seems werner doesn’t care about idling. In the east St. Louis pilot I’ve seen like 6 of them parked next to each other bobtail idling for a full 34.
  5. AlexD13
    298
    85
    Jun 13, 2016
    what do you think of a 400hp
  6. bzinger
    bzinger Road Train Member
    16,593
    65,735
    Dec 10, 2014
    omaha , ne
    Keep in mind the big fleet mentality of pump and dump ....just enough maintenance to keep the warranty intact and dump em shorty before the warranty is up .
  7. bzinger
    16,593
    65,735
    Dec 10, 2014
    omaha , ne
    Also keep in mind either of those trucks will probably need very expensive work before 700k and maybe an overhaul .
    Hulld, truckdriver31 and D.Tibbitt Thank this.
  8. JoeyJunk
    JoeyJunk Road Train Member
    8,763
    68,024
    Dec 31, 2010
    Washington, PA
    If you are buying a fleet truck, pick one from a company with APU’s that also have decent shops. Two companies with good maintenance are Averitt and Ozark Motor Lines. Both can be found on Truck Paper. This doesn’t guarantee anything but at least you know idiling was minimal.
    There are many others.
  9. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    every thought of a walmart truck.
    AlexD13 and JoeyJunk Thank this.
  10. JoeyJunk
    8,763
    68,024
    Dec 31, 2010
    Washington, PA
    forgot about Wal-Mart!!! They are very good.
  11. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    not 100% true. walmart has put in a new engine then turned in truck 6 months later cause of rotation. they have to fix everything before they turn in truck.
    bzinger Thanks this.
