Weight rating of trailers
Discussion in 'Heavy Haul Trucking Forum' started by caftransport, Jan 2, 2014.
  1. caftransport
    caftransport Light Load Member
    68
    14
    Mar 18, 2013
  3. TankerYankr
    TankerYankr Medium Load Member
    303
    470
    Jan 16, 2010
    Central US
    The weight rating is the cargo capacity of the trailer. So a 70 ton rating means that the trailer itself can carry 70 tons without risking structual damage.
  4. KW Cajun
    KW Cajun Road Train Member
    2,383
    3,652
    Apr 12, 2013
    Copperhead Road
    Here is the link to Fontaine's brochure on that particular trailer.
    It has all the info you'd want to know, plus more.
    Fontaine Mag 70
    Also a photo, with the basic description/specs.
    Cetane+ Thanks this.
  5. caftransport
    68
    14
    Mar 18, 2013
    Here's another thing I've been wondering about. Looking at Reitnouer's bigger bubba 3 axle step deck has a weight rating of 120,000 lbs. Somehow I don't think even with 46k drives you would be able take advantage of it's maximum weight. Is a trailer like that even feasible?
  6. Heavy Hammer
    Heavy Hammer Road Train Member
    1,184
    5,889
    May 1, 2013
    In purgatory
    I would like to see someone try putting 120,000 on an uluminum tri axle step deck!
    I saw someone put aproxx 93,000 on an aluminum tri hiboy...it hauled it...but the trailer was negative, and didn't come back when they unloaded..nice Tri bro!
    dannythetrucker Thanks this.
  7. caftransport
    68
    14
    Mar 18, 2013
    LOLz, exactly what I was thinking. How can they even list that weight is beyond me.
  8. passingthru69
    You also need to see what the rateing is for in the feet. I had a 85 ton trl. rated for in 16'. So that means you need to have the load spread out on it's foot print at least 16' When loading it in a smaller foot print like 10' you are over loading the rating. Good chance of ruining the trl.
    Company I was leased too had 85 ton trls. rated in 20' trying to save weight and after about 1 1/2 years the trls. started going neg. as alot of theirs lds. were like 12' foot print
    281ric Thanks this.
  9. snowblind
    snowblind Heavy Load Member
    775
    636
    Jan 29, 2011
    conover nc
    most will haul more than their rated.you will know when exceeded when it breaks
  10. DMH
    DMH Medium Load Member
    344
    110
    Jan 9, 2012
    Would need more than 3 axles on the trailer if you ask me. I get permits for well over 46k on the drives around here all the time though. Not with that much weight on the trailer though. macs trailers are rated up to 120k spread out over 48ft and 100k in 20ft.
  11. Cetane+
    Cetane+ Road Train Member
    1,304
    882
    Sep 29, 2013
    Albany, NY
    If you could get permitted for what the trailer axles are made for, it would be easy. 14+23+23+20+20+20=120,000. I have hauled 120,000lbs. on 6 axles with my loader trailer many times. Its a little over whats legal here, but trucks and trailers have held up for years with that kind of weight.
    baha Thanks this.
