weight of gasoline and diesel
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by driver81, Apr 26, 2015.
  1. driver81
    driver81 Bobtail Member
    47
    6
    Feb 6, 2013
    I haul fuel, and I know about how much my equipment weighs when i'm empty, does anyone know how much does gasoline and diesel weigh pounds per gallon? When I asked other drivers, I get different answers, anywhere from 6-8 on the gasoline and 7-9 lbs/gallon on diesel. And do you look at the gross or net gallons to figure out the weight of the load? Thanks
  3. Allow Me.
    10,642
    12,099
    May 28, 2009
    Rancho Mirage, Ca.
    I think diesel fuel is 7. something. Rule of thumb is figure 8 lbs per gal. Gasoline is a hair above 8lbs, I think.
  4. Rugerfan
    Rugerfan Road Train Member
    7,010
    33,635
    May 3, 2011
    Redding,CA
    I've always figured it into my weight at 8 lbs. per gallon and that has worked out pretty well for me.
  5. Hyweighman
    Hyweighman Medium Load Member
    517
    659
    Dec 29, 2011
    Pensacola, FL
    Gas 6 lbs a gal. Diesel 7.1089 lbs a gal
  6. Ringo1
    Ringo1 Light Load Member
    89
    131
    Apr 20, 2014
    South Carolina
    I've used 11lbs as a standard for diesel. I got that number from a fuel hauler in the 90's.
  7. Dr_Fandango44
    Dr_Fandango44 Road Train Member
    1,053
    746
    Aug 27, 2012
    Austin, TX
    No it's the other way round.
    Gasoline is lighter than fuel.
    gas is around 6lbs and diesel at 7lbs. I've loaded too many loads to mention and I had to cut a diesel load way back to stay legal. I hauled fuel in TX
    chalupa Thanks this.
  8. not4hire
    not4hire Road Train Member
    7,142
    26,957
    May 16, 2012
    Calgary
    Did he look like this?
    It was because he inhaled too many fumes, had brain damage and was way wrong.
    Mr.X and Rugerfan Thank this.
  9. driver81
    47
    6
    Feb 6, 2013
    Thanks for the answers. Do you figure the load out from the gross or net gallons from the rack ticket, or does that really matter?
  10. FLATBED
    FLATBED Road Train Member
    Gasoline is supposedly 6.183 LBs / Gallon at 72'F and as it's density is effected by temperature change from 72'F COLDER = HEAVIER , WARMER = LIGHTER
    Diesel I usually figure at average weight of 7.1 LBs / Gallon
    heyns57 Thanks this.
  11. SLANT6
    SLANT6 Road Train Member
    1,094
    1,376
    Dec 3, 2012
    The Nut House
    Hold all calls. We have a winner
