Weight Limits on Bridges
Discussion in 'Questions To Truckers From The General Public' started by Ducks, Jan 20, 2008.
  1. Ducks
    Ducks "Token Four-Wheeler"
    3,415
    3,581
    Jan 1, 2007
    Southeastern Pennsylvania
    A trucker stopped me the other day near one of the older bridges crossing the Schuylkill River. He admittedly was lost (easy to do on some of our meandering back roads here) and when he told me where he was headed, I knew he had missed his turn and I had to get him headed in the other direction.
    I informed him that the company for which I work had a warehouse about a quarter-mile on the other side of the bridge, and we had a paved turnaround area for trucks. His first question was, as he looked at the old bridge, was did I know the weight limit on it. Nope, I didn't... but I knew that trucks used to cross there all the time when the nearby distillery was operational umpteen years ago.
    So he said he'd take his chances, then crossed, turned himself around, and headed back to his destination.
    Afterward, curiosity got the better of me and I took a stroll around the bridge but could find no identification plate or indication of weight limits. How do truckers know (or how are truckers supposed to know) what the weights limit are on some of these local bridges?
  3. Scarecrow03
    Scarecrow03 Road Train Member
    3,411
    7,443
    Sep 27, 2006
    In Your Head
    It's up to the governing authority of the road that the bridge is on to make sure it's properly marked to indicate its weight limits. For example, if that was a rural state highway, then the state would be responsible. If it was a county or township road, then that government agency would be responsible for it. If there truly were no signs, I'd let the appropriate agency know about it.
    snowlauncher Thanks this.
  4. MXH
    MXH Light Load Member
    101
    6
    Jan 28, 2006
    A Motor Carrier Atlas has lists of restricted routes in a state-by-state format. Also included are low clearance points for trucks.
    As far as I know, only common sense can tell a driver whether or not to cross an unmarked bridge that not on a restricted route.
  5. Burky
    Burky Road Train Member
    Legally, if there is no restriction signage on a bridge, then it is the same rated weight as the roqadway approaching it. If it is a state owned street and there are no restrictions posted on the street, then it is up to the full legal weight of 80k. If the street is restricted, then the bridge is part of the roadway and falls under the same restrictions.
    But, whenever you encounter an old bridge, it's always a moment for a gut check, and wondering if this is finally going to be the time that exceeds the limits of the bridges design.
    A couple of years ago, I was crossing a bridge on a highway in Kentucky, right on the northern border. No weight limit signs at all as i approached the bridge. Suddenly, I spotted a sign, with weight limits of some kind on it, and jammed the brakes because the numbers I saw were lower than my weight. I stopped right there, hit the flashers and tried to figure out how I was going to back down the approach from the bridge and find another route to my delivery. Another truck came up behind me, and I talked to him on the CB. Turned out that the sign I had just gotten a glimpse of was restrictions for coal trucks only. Everyone else was fully legal to cross it. Peroblem was that there was so much info on the sign, I didn't have a chance to read it, merely catch the pertinent numbers.
    Better safe that sorry, and wet!!!
  6. panhandlepat
    panhandlepat Road Train Member
    3,255
    2,243
    Jan 12, 2007
    what it doesn't tell you is the weight limit. i have crossed bridges designated as a truck route but with weight limits less than 40 tons. the only way to know is when you get right up to the dang thing.:biggrin_2554:
  7. Burky
    Always remember that the 80k limit only applies to interstate roads. Once you leave the interstate, or go past what is considered "reasonable access" you can find yourself dealing with state limits. I make one run into Carol Stream Il where I am at 80k for the entire trip, and the last 1/4 mile to the customer is a road listed as a truck route, but the weight limit is the states limit of 72,380. I still drive there since there is a very limited chance of them catching me, but the weight limit is there and real, it's just not enforced very well.
    The local cops probably have much higher priorities, so I hope they don't ever have a slow day.t
  8. 25(2)+2
    18,749
    45,388
    Sep 18, 2006
    the road less travelled
    In answer to the original poster, if there is a weight limit on that road, the limit on the bridge which is otherwise unmarked would be the same as the roadway, and the truck atlas doesn't have everything in it.
    IL has the Class II and Class III truck routes, Class II is the same as everywhere else, that is a state roadway, except where those roadways are restricted, 40 tons GCVW. Class III might be 73,280 or it might be shorter length or both. I have seen that portion of road in Carol Stream and have been warned to avoid it, especially if the local doughnut fund is in need of replenishment. I'm never near that road at the weight of 73280, always have the first drop near that town.
    MN has 10 tons per axle limits on county roads equaling 40 tons for the vehicle, 9 tons per axle is equal to 73,280. There is a bridge marked 45 tons permit weight for any vehicle, only the front or the back of a standard combination vehicle would be on the bridge at one time. This pavement is marked at 10 tons per axle in that county.
    Arkansas is notorious for having lower posted weights limits on bridges on truck routes without advising you until you are about to cross them. I'll drive in OH any day over Arkansas.
    In IA, if the cargo is alive and you have a spread axle trailer, you can gross 86,000 on non Interstate truck routes, meaning primary and secondary highways unless otherwise restricted. Interstates are restricted to 80 K except by permit.In the fall if the grain hauling emergency is in effect, you can gross 10% over the otherwise legal axle limits of 12, 34, and 34 thousand lbs on each axle set(88K gross)without a spread axle trailer for grain only and again not on the Interstates. New this past year was the axle limits set at 10% over instead of the gross weight limit of 10% over.
    There is more, wherever you are from.
  9. xr7conv
    xr7conv Light Load Member
    That's what I understood, at least up to 80,000 pounds.
  10. Mototom
    Mototom Road Train Member
    1,388
    2,703
    May 7, 2019
    Arkansas is worse then that. They found trucks had a quick route through the backroads and dropped weight limit on the bridges down from 40tons to 37tons.
    they also restricted some bridges on a county road by some farms to 12tons, while everyday trucks 60K lbs plus rolls over it every hour.
    Some of this is just a scam meant to take money from drivers.
    bzinger and nredfor88 Thank this.
