Weight Distribution For Driving/Ride Quality
Discussion in 'Questions From New Drivers' started by Damaged_Goods, Sep 20, 2019.
  1. Damaged_Goods
    Damaged_Goods Light Load Member
    74
    91
    Apr 9, 2016
    Hey Guys. Quick question...
    If you’re weight difference between your Drives and Tandems are 5,000 lbs but you’re legal, so you don’t really have to slide your tandems.. but should I anyway to distribute the weight more evenly?
    Example
    Steers ~ 10k,
    Drives ~ 28k,
    Tandems ~ 33k,
    What would give me the best ride quality?
    (Truck suspension/Uphill pull/Starting from a stop, Optimal power etc)
    Should I ........?
    Slide the tandems to even out the weights
    -OR-
    Leave the weights as they are? (Tandem heavy)
    -OR-
    Reverse the weight and make the Drives more heavy?
    Or it won’t really make a noticeable difference at all, no matter what I do?
  3. Intothesunset
    Intothesunset Road Train Member
    2,289
    4,880
    Apr 15, 2019
    truck
    Put the most weight possible to be legal on drives. But if almost even weights yet a bit more on drives is best ride.
    Lepton1, starmac, TravR1 and 2 others Thank this.
  4. Ubu
    Ubu Road Train Member
    1,252
    1,178
    Aug 25, 2012
    Rumored to be somewhere
    I always try to have a little more weight on the drives vs the tandems but close to balanced. When the tandems are heavy it always feels like someones tugging backwards on the truck when going up hill.
    In the winter I put a bit more weight then in the summer on the drivers for traction.
    Damaged_Goods, Lepton1, TravR1 and 5 others Thank this.
  5. TripleSix
    127,950
    I prefer the drive to be heavy. A much heavier trailer gives you the ‘tail wagging the dog’ feel. In bad weather, this can lead to handling issues.
    Damaged_Goods, Lepton1, TravR1 and 6 others Thank this.
  6. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    ED5EECC3-A96F-459C-B8F4-ED7A6A56AA33.jpeg I ride like this most often. we have spring trailers
  7. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    air ride trailer or spring.
  8. Damaged_Goods
    74
    91
    Apr 9, 2016
    Air Ride
  9. Anywhichwaybutloose
    Anywhichwaybutloose Light Load Member
    157
    263
    Jun 24, 2017
    Its not the weight on the tandems as much as the weight behind them.
    Fixing overweight drives by putting some heavy freight on the rear. Make it legal bit rides like ####.
  10. MACK E-6
    48,113
    219,512
    My worst day for that was one when I had 12k on the single driver and 28k on the trailer tandem. That sucks on a normal day, but that day a snowstorm moved in as soon as I left the yard.
    I never made it to my route. Turned around and went back, and almost didn’t make it back.
    FlaSwampRat, TravR1 and truckdriver31 Thank this.
  11. Swine hauler
    Swine hauler Medium Load Member
    348
    2,233
    Jun 21, 2019
    In snow i will max out of even go 1000 lbs over on the steers(slide 5th wheel) to make the front end stick to the road, max out the drives and then some for maximum traction, tandems can trail along. ( steep grades and gnarly roads around here).
    Lepton1, MACK E-6 and FlaSwampRat Thank this.
