Anyone that has changed the weatherstripping on your sleeper storage box doors, what kind of adhesive do you recommend I buy?
I'm assuming after I cut the old one off, I'll have to take a heat gun and melt away all the old adhesive so that the new weatherstrip sticks cleanly?
Weatherstrip door seal adhesive recommendation
Discussion in 'Ask An Owner Operator' started by JonJon78, Sep 10, 2023.
Flat Earth Trucker, DeereRunner97, 4mer trucker and 2 others Thank this.
I've used this in a few different applications. Works great. Glued the exterior door moldings of one of my cars back on when the factory 2 sided tape failed. Never came off again.
Flat Earth Trucker, Vampire, 86scotty and 1 other person Thank this. -
Some high end 3M tape will work as well if can’t find anything else. Just make sure it is weather and perm sticking tape.
If it is a metal insert in the channel that fits the metal, then you don't need adhesive, you crimp it to the metal.
Rideandrepair, IH9300SBA, Siinman and 3 others Thank this. -
3M weatherstrip glue.
The duck tape of the glue world .Siinman, Vampire, Oxbow and 1 other person Thank this. -
The only places i’d glue would be the corners and a few inches on each end at the splice. That will help with expansion and shrinkage during extreme temp and climate changes. This helps keep the corners from sagging and the joint from pulling apart.
I did replace those when i had pete and never used any glue , just squeeze it bit with fingers all along and install. -
I replaced the sleeper door on the ICT and side water door - I got some from Amazon, but ran into an issue with it not being quite right - and the lock mechanism would either be too loose and not seal, or too tight and not latch. Bought 2 sets of different size.
A little adhesive in the corners to handle shrink/expand should be all you need.
I settled at an unhappy medium, so I'll be interested to see how this works out for you.Flat Earth Trucker, Siinman, 4mer trucker and 1 other person Thank this.
