Water in engine oil dipstick not in the oil pan
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Ruckie, Mar 9, 2016.
  1. Ruckie
    Ruckie Road Train Member
    1,485
    1,029
    Nov 12, 2011
    Bloom field,nj
    Well I have a 2006 century class ex sni I found water on my dipstick so I changed the oil looking for any indication of what's going on and didn't found anything, no water in the oil being replaced, about 10 minutes ago I checked the oil dipstick and found water my mechanic told me it could be the oil cooler or the engine is gone mind you the engine has only 717k miles.... Can you guys tell me anything about or should I just start looking for another truck?
  3. strollinruss
    strollinruss Road Train Member
    1,366
    1,699
    Jun 5, 2012
    Montgomery, TX
    Change the oil cooler and try it. Cheapest thing first.
  4. agitator
    agitator Light Load Member
    65
    80
    Apr 21, 2012
    the cheapest thing to do is run a oil sample....could just be condensation....highly unlikely but you never know...
  5. TAfool
    TAfool Medium Load Member
    631
    850
    Dec 8, 2012
    No, don't just change parts.
    Do a combustion leak test. Fail? Head, gasket, liner etc. Pass? Test cooler. Replace only failed parts.
    Don't be a parts changer.
    TA
  6. AModelCat
    154,240
    Water or coolant? If its coolant I'd be concerned. If its just a bit of condensation I'd maybe check your blowby tube and make sure its clear.
    Straight Stacks and Cottonmouth85 Thank this.
  7. Ruckie
    1,485
    1,029
    Nov 12, 2011
    Bloom field,nj
    It's coolant I had to put a gallon of it today
  8. Cetane+
    Cetane+ Road Train Member
    1,304
    882
    Sep 29, 2013
    Albany, NY
    You have GOT TO find out where it is coming from. Dont just change parts blindly.
  9. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Yeah and don't keep on driving it either.
    Coolant will wipe your bottom end bearings and then you'll have even bigger problems.
  10. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    First, check and see if there is oil in radiator. If not your cooler is fine. Could be a cracked head or bad headgasket, bad o-rings on liner, pitted liner. Figure it out before you ruin your engine.
  11. Ruckie
    1,485
    1,029
    Nov 12, 2011
    Bloom field,nj
