Water in DEF tank?
Discussion in 'Ask An Owner Operator' started by MakinMovesFast19, Feb 9, 2020.
  1. MakinMovesFast19
    MakinMovesFast19 Bobtail Member
    Have anyone here ever heard of using water in the DEF tank? Is this safe to do?
  3. Mid-May Trucker
    Mid-May Trucker Road Train Member
    1,118
    2,079
    Oct 23, 2018
    No it has sensors that tells what the liquid is made of.
    PE_T Thanks this.
  4. RockinChair
    RockinChair Road Train Member
    4,918
    12,257
    Feb 19, 2012
    CC, TX
    It will cause your engine to de-rate or shut down.
  5. AModelCat
    154,260
  6. Ridlingdj
    Ridlingdj Medium Load Member
    414
    562
    Dec 12, 2018
    It will work about as well as using water in your fuel tank
    RockinChair Thanks this.
  7. mhyn
    mhyn Road Train Member
    4,255
    4,510
    Dec 29, 2008
    Northridge, CA
    not all trucks have that sensor.
    if scr is bypassed you can use distilled water.
  8. AModelCat
    154,260
    Will the lack of NOx conversion thru the catalyst not be picked up when the aftertreatment control module compares inlet vs outlet NOx? I know some did it that way prior to 2018 when DEF quality sensors became mandatory.
    mhyn Thanks this.
  9. Roberts450
    Roberts450 Road Train Member
    2,237
    3,635
    Feb 6, 2016
    Just incase ya don’t know DEF is 32.6% urea and 67.4% water.
    mhyn Thanks this.
  10. mhyn
    4,255
    4,510
    Dec 29, 2008
    Northridge, CA
    let outlet nox sensor sniff clean air. Nox conversion is 100%. you can put water in def tank..
    AModelCat Thanks this.
  11. Freddy57
    Freddy57 Road Train Member
    1,731
    8,246
    Nov 29, 2013
    Mount Vernon, MO
    They use deionized water to prevent the nitrogen molecules from binding themselves to other molecules. Straight water will cause problems with the distribution. The new trucks get errors from it.
