I have 3 wheel bearing on my Peterbilt that are a little Loose. Nothing major but want to take care of them before they get worse truck has 500,000 miles. Thanks
Was curious about how much it cost to change wheel bearing in my Peterbilt tractor.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Big Lou, Feb 7, 2015.
Big Lou Thanks this.
might not need new bearings depends on how loose for how long
Big Lou Thanks this. -
just tighten it. oh if it little loose when its cold that's good
do it asap or you'll be calling the axle doctor (surgeon) when it fails and need a new spindle. :/
A little loose is never good, cold or not. pull the axles and if the oil isn't metallic looking you should be ok snugging them up. However if your already that far might as well pull and inspect races for pitting and just replace. Too cheap of a part to leave you stranded.
That's what I figured might as well just do it if they are off. Was just curious on how much I was looking at for cost. Thanks everyone!
Front axle bearing on one side, and tightening loose one on drive ( new nut ) run me 400. I was quoted 550 for front only by some other shop.
bearing and race set is like 60 X 2 sets so like 120 for parts for one wheel.
