I have notice in the past two weeks that many drivers have no idea how to properly set out warning triangles so:
1. When your truck is at the TOP of the hill or slightly down hill or obstructed by a curve place triangles in following manner:
one triangle 100ft = 40 PACES to front of vehicle (yes some walking required)
one triangle 10ft = 4 PACES to the rear of vehicle and
one triangle 100-500ft = 40- 200 PACES to the rear of vehicle (yes more walking is required)
2. STRAIGHT Two Way Road: one triangle 100ft = 40 PACES to front of vehicle
one triangle 10ft = 4 PACES to rear of vehicle and
one triangle 100ft = 40 PACES to rear of vehicle
3. When Y.O.U have BOTH lanes blocked:
4. On DIVIDED Highways:
no triangle in front of vehicle
one triangle 100ft = 40 PACES to rear of vehicle and
one triangle 200ft = 80 PACES to rear of vehicle.
Feel free to copy and tape to your dashboard!
These are the correct methods to use in setting out your warning triangles people.
aimhigh
WARNING DEVICE: The correct method to set up!
Discussion in 'Questions From New Drivers' started by aimhigh, Aug 9, 2014.
Page 1 of 3
Very nice... thanks!
Great piece of info aimhigh.Even though they should I wonder how many actually do it that way though.
Some drivers don't know how to set triangles and some drivers can't find the correct section to post their topics!
You have some short legs if 40 paces = 100ft, just saying....
32 paces for me.
Good post, thanks!HotH2o Thanks this. -
I can honestly say, in all my years, I don't think I've ever seen 2 triangle setups the same way. I've seen them all grouped together, hanging on the back of the trailer, once on the fuel tank, and most don't have them out at all, and I think I've seen the pattern on the inside of the box. I've even seen them supported by a rock, because the driver didn't know how to open them up. I've always known about the 100, 10, 100, but even I was unaware of the divided highway one. I'm such an old-timer, the first truck I drove in the early 70's, had the 2 round reflectors in the metal box.
pattyj Thanks this. -
You forgot to mention that triangles must be set up after you have been on the shoulder for ten minutes. I always carrey to sets because the stupid four wheelers will run them over and you are still responsable to have them set up regardless.
aimhigh Thanks this. -
This is a very important regulation as mentioned above seldom do you see triangles set up right,,only takes a couple mins to be safe and it only takes a couple seconds to die.I carry a cheap battery operated orange flashing light,,when ever on the side of the road or a ramp with a flat or broke down I put it on the rear of my trailer..sometimes when having to spend the night in a rest area I put out my flashing light,,remember to use your 4 way flashers too.
The box even tells you
[QUOTE="semi" retired;4178267]I'm such an old-timer, the first truck I drove in the early 70's, had the 2 round reflectors in the metal box.[/QUOTE]
I've still got a set of those somewhere...
I'm always amused by the creativity of drivers who just don't know what they are doing. Considering their purpose is to warn approaching traffic about your disabled vehicle, putting them on or grouping them in close proximity to the vehicle always seemed pointless...but seeing as how so many get this simple little task so wrong I'm curious how many LEO's are aware of the proper way to have them set out?Criminey Jade, 48Packard and "semi" retired Thank this.
Page 1 of 3
