Wanting to remove IVA on NXS
Discussion in 'Trucks [ Eighteen Wheelers ]' started by bigrig9, Dec 19, 2011.
  1. bigrig9
    bigrig9 Bobtail Member
    4
    Red Deer
    Looking to remove IVA on NXS engine and change back to 6NZ style top end. I have 3 NXS CAT engines and 1 BXS CAT engine and it seems I'm always changing solenoids or wiring harness and its getting old. Any help would be appreciated thanks.
  3. 07-379Pete
    07-379Pete Crusty Commando-Pete
    2,549
    2,347
    Oct 3, 2008
    Campbellsville, Ky
    Changing the top end to a 6NZ or any thing other than a ACERT and no CAT shop will touch it. I asked the shop I use and was told the same thing, they wont even run an overhead on one thats been changed.
  4. Nevs
    Nevs Light Load Member
    295
    107
    Dec 25, 2010
    flyover country (Iowa)
    He does bring up an interesting question though. Could you eliminate the IVA's while still keeping the twins? Or would a turbo and manifold swap be needed to make it work properly? In my case a Cat shop not wanting to work on it wouldn't be an issue. I've got two different people who would be happy to have my business.
  5. bigrig9
    4
    Red Deer
    I'm not worried about the local CAT shop. I'm pretty sure as long as you had a parts list of what was done to the engine so they new what was what they would be good with it. I talked with a guy today that changed his back to a single turbo and apparently the shop that did it just backed the IVAS off and changed the ECM program so they were none functional and he said it works great. I would like to keep the twins just get rid of the rest.
  6. Oscar the KW
    Oscar the KW Going Tarpless
    12,246
    28,114
    May 19, 2011
    If your going to that on an nxs its going to get very expensive. I don't know if you can keep the twins but you will need to buy a new engine wiring harness, head, and who knows what else. In over a million miles I have only had a problem with one iva solenoid.
  7. bigrig9
    4
    Red Deer
    Are you sure the head would be different?
  8. ROBSREDFORD
    ROBSREDFORD Light Load Member
    266
    139
    Sep 2, 2008
    MIDLAND, NC
    Wrong answer head is same . It's long answer call me tomorrow 7045072453
  9. bigrig9
    4
    Red Deer
