Want to switch from duals to single wide tires
Discussion in 'Trucks [ Eighteen Wheelers ]' started by sicshovel, Apr 15, 2012.
  1. sicshovel
    sicshovel Light Load Member
    65
    8
    Sep 2, 2010
    Hager City Wi.
    Currently running 24.5 LP's? Do the single wide tires come in 24.5's or 22.5, how do I keep the gearring the same? I have looked on Ebay, I cannot find any used ones for sale, a friend of mine said you need to get the ones with the shallow offset to keep the tires centered on the bearings vs. the deep offset which brings the tires out to the same position as the outside dual would. I know nothing about super singles, any advice whatsoever will be greatly appreciated. Thank you in advance.
  3. marmonman
    marmonman Road Train Member
    1,417
    2,842
    Dec 14, 2009
    central illinois
    Go to your tire man and ask him the finer points on switching over . Be sure to sit down when they tell you the cost for all new parts to switch over .
    I myself don't see enough difference in fuel savings or wear on truck or cost of tires to spend the money but that is just my OPINION and we all think ours don't stink .
    If you don't have a tire man just stop and ask as many tire shops as you can.
  4. belltransit
    belltransit Light Load Member
    271
    27
    Jun 28, 2010
    oak grove, mo
    marmonman is correct. just for s&g ive asked tire shops what the price of one of those super singles is.....$1000+ for just one tire. and if u have a blowout u have to sit and wait for a service truck. u cant limp on down the road and get to a shop to get it fixed.
  5. granhawler
    granhawler Light Load Member
    296
    56
    Feb 26, 2011
    As far as I know all super singles are 22.5's but there is one size that is the equivalent to a lo pro 22.5 and another size that is equivalent to a low pro 24.5
  6. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    Europeans use single tires on trailers and I'd say yep, better an lighter the twins, but trucktor drive tire is too wid to be secured on frame as spare one
  7. mkonei
    mkonei Bobtail Member
    11
    May 22, 2011
    If you have 24.5LPs now, you will need the 445/55R22.5 to stay in the same rev range. That will keep your gearing unchanged. On the wheels themselves, youll want either a 0" offset wheel, or a .5" offset wheel. Stay away from the 2" offset wheels that move the wheel out, they beat the hell out of the wheel bearings.
  8. black_dog106
    black_dog106 Road Train Member
    1,786
    1,666
    Mar 29, 2009
    MA
    This has been debated many times before in many threads. I have always perfered duals over SS. I have pulled SS single trailers but never driven a tractor with SS. I am always heavy and all local work. A friend in CT drives a dump truck with SS and he says it sucks in snow(i have no doubt).
    As has already been said, if I lose one, i always stop. The wheel is never on the road, but i dont take the chance. I can dump the air out of suspension, chain the wheel (axle) up to bunk, then reinflate suspension to get home, but still have to stop. They do slide around easier in mud, snow. I can go on, but those are the biggest reasons.
    Maybe in an otr rig where every pound counts, maybe, but not for me.:biggrin_25514:
  9. Starline
    Starline Medium Load Member
    357
    251
    Jun 1, 2011
    Middle Tn
    There is a thread about singles in the Owner operator forum... check it out.
    I've been running a 2" offset for about 360,000 miles and on my second set with no issues.
    I've run both duals and now a wide base and prefer the wide tires and not had any issues.
    BTW, 445/50/22.5 = lo pro 22.5 & 455/50/22.5 = 11R22.5
  10. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    Info correct. A side note... the 455/50/22.5 = 11R22.5 also equals Low pro 24.5.
  11. sicshovel
    65
    8
    Sep 2, 2010
    Hager City Wi.
    i found a set of 22.5 14.00 wide rims but not sure off the offset, they stilll have wheels on them, should the offset be stamped on the outside of the rim or is there a way to measure it? from the center of one set of my duals to the center of the other measures 74 inches, peterbilt told me that they recommend 2 inch offset with this measurement, thanks again
