Want to add Jake
Discussion in 'Trucks [ Eighteen Wheelers ]' started by jmlloar, Mar 4, 2010.
  1. jmlloar
    jmlloar Light Load Member
    100
    13
    Jun 13, 2009
    Keyser, WV
    I have a cummins 290 in a 79 GMC Astro and want to add a Jake brake to it. Can it be done? Hard or easy? alot of parts need changed or pretty much bolt in?
    Could really use some help. Any info greatly appreciated.
  3. stranger
    stranger Road Train Member
    3,640
    4,959
    Oct 10, 2006
    NC
    Adding a Jake to a 290 is a very easy job. There are people on here that hopefully will give you detailed instructions.
    This is probably one of the easiest engines to do this to.
  4. Longhood379
    Longhood379 Medium Load Member
    389
    125
    Nov 30, 2009
    Cremona AB
    The Jacobs engine brake was designed by Cummins himself but the board of directors didn't support his indevor, so he sold his shares , bought Jacob chuck built the brake , the rest is history so yes it is easy to put jake heads on the 290 , you need 3 heads that match your cam , a bolt kit some gaskets a couple of microswitches and some wire . :biggrin_25515:
  5. Heavyd
    Heavyd Road Train Member
    7,804
    6,253
    Feb 4, 2009
    I might be a little hard to find a new kit, here is link to the website you can get started collecting information. Jake Brake needs the CPL number with any Cummins engine. If you can get the CPL number off the engine, then you can get the kit part number from Jake Brake, then you go to any Cummins dealer and order that kit.
    http://www.jakebrake.com/
  6. Brickhauler
    Brickhauler Medium Load Member
    411
    142
    Oct 1, 2008
    Elizabeth CO
    There are so many of them out there you should have no problem picking up a used set to fit your engine fairly inexpensively. Along with the jake brake housings themselves mentioned in an earlier reply, you will also need to get the exhaust rocker arms that are cut down for the Jake Brake actuators to fit over along with the special jake brake crossheads for the exhaust valves. The set screw that holds the rocker shaft in the rocker box is a special hollow screw as well, thats how the oil gets up to the jake brake. You also need longer rocker box mounting studs.
    Small or big cam as well as single or dual entry turbo makes a difference on which model jake brake you need for your engine.
    There used to be an installation kit available that had the wiring harness, dash switches, clutch and fuel pump switches. Basically all the electrical parts. I don't know if they still sell that though.
    If you get all the parts together, its pretty much a bolt on job. My opinion is the easiest way to do it is find a core engine at a truck salvage place and get everything all at once. I sold a complete Model 425 setup on ebay about 5 years ago and I think it only brought around 300 bucks, I can't remember exactly but it seemed like it went pretty cheap to me.
    jmlloar Thanks this.
