Walls inside of a reefer trailer
Discussion in 'Experienced Truckers' Advice' started by PhoenixPete379, Jul 28, 2021.
  1. PhoenixPete379
    PhoenixPete379 Bobtail Member
    4
    Jul 19, 2021
    Was wondering if anyone has ever sprayed down the walls of an older reefer trailer with some rhino line or anything like that. Is it plausible?
  3. Ridgeline
    22,114
    113,316
    Why?
    the walls are not important, the insulation is and they degrade enough the reefer needs to be scrapped.
  4. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,470
    Nov 7, 2007
    Possum Booger, Alabama
    Do not spend money trying to beautify an old reefer trailer. It's money down a hole.
    That being said, almost nothing sticks to Kemlite, it would probably peel back off in huge sheets, then you'd have one hell of a mess.
    Reason for edit: Typo
    ncmickey Thanks this.
  5. PhoenixPete379
    4
    Jul 19, 2021
    Awesome thanks for the responses guys. Those are good points
  6. Dockbumper
    Dockbumper Road Train Member
    3,778
    9,860
    Apr 29, 2020
    Yup.....like lipstick on a pig.
    bzinger and lilillill Thank this.
  7. SteveScott
    SteveScott Road Train Member
    4,897
    16,806
    Nov 10, 2015
    The blue and red paint from painted pallets sticks great. You can't get that crap off.
    BoostedTeg, Oxbow and lilillill Thank this.
  8. bad-luck
    bad-luck Road Train Member
    3,252
    5,954
    Nov 16, 2013
    Baltimore, Maryland
    I would not waste money on the inside of an older trailer. If you have holes or tears where the insulation is exposed, use outdoor window sealer. Before you decide on which one to purchase, read the label for the temperature ranges.
    bzinger Thanks this.
  9. lilillill
    5,642
    13,470
    Nov 7, 2007
    That stuff even stains the walls of my new trailer that has some magic non-stick stuff that is super slippery. I've tried every pressure sensitive adhesive vinyl known to mankind, trying to put the unit number inside... no deal, they fall off after a day or so. But Chep paint, yep, doesn't come off even with Purple Power and a pressure washer.
    SteveScott Thanks this.
  10. wichris
    wichris Road Train Member
    4,243
    8,447
    Jan 17, 2011
    Nothing gets it clean and everything stains it. Phosphoric acid does take a lot of the stains off.
  11. jason6541
    jason6541 Road Train Member
    2,425
    5,365
    Mar 5, 2012
    Omaha, NE
    Have you tried magic erasers?.
