walking floor vs dump trailers
Discussion in 'Questions To Truckers From The General Public' started by jl28, Aug 10, 2010.
  1. jl28
    jl28 Bobtail Member
    25
    9
    Jun 12, 2010
    cent.ny
    whats the advantage of using a walking floor trailer instead of just a dump [gravel type] trailer?especially since alot of landfills have atipper that lifts the whole trailer anyway.It seems the walkingfloor trailers have alot more moving parts and are expensive [made of aluminum].Thanks.
  3. Crash935
    Crash935 Medium Load Member
    329
    164
    Sep 8, 2007
    Wyoming Mi
    If you pull a dump type trailer into the landfill you will be dumping it yourself and not using the tipper. The trailers that go on the tipper are usually non mechanical, no hoist, no walking floor.
  4. davenjeip
    davenjeip Medium Load Member
    459
    257
    Dec 20, 2009
    Port Charlotte, Fl
    I used to pull walking floor trailer and empty at the landfill. Have never pulled a dump trailer.
    The landfill is pretty much a big hole that's been filled in with compacted garbage, then covered with dirt on a pretty regular basis. That results in a pretty soft surface, especially with just a little bit of rain. If it were me, I'd be scared to use a dump trailer on something that was not more compact.
    Your situation could be different than what I was seeing, but I can tell you that it's a pretty rough environment for a truck. I'd pull for a large company who could do the repairs and maintenance, but would never subject my own truck to those conditions.
    The upside is that pulling garbage is awesome. You never have to worry about damaging the load, people don't want to tailgate you as much, and DOT is not nearly as willing to crawl up under your trailer.
    lovesthedrive and Big Duker Thank this.
  5. U4EA
    U4EA Road Train Member
    1,014
    506
    Dec 2, 2009
    There application/use is different.
    Walking floor trailers are 48' trailers designed to haul trash, construction debris, mulch - etc. Dump trailers are much smaller in length and capacity (the short ones are around 26' trailer) and are used to haul gravel, dirt, rock - etc. But for instance, its not uncommon for a 26' trailer to be filled with water logged soil being removed from a construction site, to weigh close to 100,00o lbs. when filled to capacity. If you filled a live floor trailer with that kind of material - it would be insanely heavy - so heavy in fact, that it would probably tip going around a corner at 10mph.
    Dump trailers are piston raised (most, not all) from a horizontal position to probably about 60 or 70 degrees from trailer chasis/frame, to the bottom of the dump trailer bed when fully extended (not exact, I don't know the exact engineering specs on dump trailer mechanics). Live floor trailers push the debris out of the tailgate.
  6. 0321jarhead
    0321jarhead Bobtail Member
    21
    15
    Apr 9, 2010
    Antioch,CA
    I have done them both. Walking floor is a pain in the butt. Especially when it rain. Opossum belly trailer (48 footer) on a tipper is the way to go. You can get a nice heavy load. Its alot faster. Unless you while its dumping you get a jam. That get resolved easily in most cases with an excavatore. When it rains, you are clean and dry. Just unhook an then re-hook up. Walking floor is just a big mess.
  7. Allow Me.
    10,813
    12,788
    May 28, 2009
    Rancho Mirage, Ca.
    I too, have done both. I liked the walking floor. I hauled sawdust to horse ranches. No worries about level ground.
  8. 0321jarhead
    21
    15
    Apr 9, 2010
    Antioch,CA
    You had a gravey job for horses. I was taking everyday garbage to the landfill site. That is what I was baseing my experiance with.
  9. trhodarm
    trhodarm Bobtail Member
    Can anyone tell me the cost to ship on a walking floor trailer as compared to a regular trailer , same size.
  10. Scania man
    Scania man Road Train Member
    2,199
    483
    Jul 1, 2011
    Saskatchewan
    I would go for walking floor, safety is one reason, you can unload on any surface and the other reason is the walking floor is more versatile , bigger volume for one (great for sawdust) and you can also haul palletised loads so it keeps your options open
