walking floor trailers, one brand better than others?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by granhawler, Apr 19, 2015.
  1. granhawler
    granhawler Light Load Member
    296
    56
    Feb 26, 2011
    Possibly going to buy a walking floor trailer this year, is one brand better than another? Any info would be appreciated.
  3. Star4900
    Star4900 Medium Load Member
    607
    521
    Mar 16, 2015
    Northern Ontario
    Can't say who is better, as I've only used two brands.....Temisko and Titan. They pretty much all use Keith floors as far as I know.
    I like the aluminum Titan....and with the heavy duty Vee-floor and cleanout blade you can pretty much haul anything. Besides chips and bark I have hauled logs, slabs and aggregates in mine. But if you are in cold climates make sure you get a liner or calcium tank, or be prepared to shovel the nose and sides off.
    The Fiberglass coated wood Temisko was nice in the winter. Stuff doesn't freeze in them as bad, but they are heavier than the aluminum trailers and not quite as strong for loading stuff like logs or scrap.
    I've looked at MAC and Stargate and have friends using them. They seem good so far.
  4. poppapump1332
    poppapump1332 Road Train Member
    2,987
    2,465
    Jan 2, 2010
    birdsboro,pa
  5. bigguns
    bigguns Road Train Member
    2,846
    6,853
    Jun 13, 2013
    Omega,GA
    You need to be specific about what the trailer is intended to be used for. You don't need info on an East unloader (a trash trailer) if you really need a thin skinned trailer. You will get better info if we know what you will be hauling.
  6. granhawler
    296
    56
    Feb 26, 2011
    99% of the loads would be wood chips to the local ethenal plant & an occasional load of palletized livestock feed.
  7. bigguns
    2,846
    6,853
    Jun 13, 2013
    Omega,GA
    Here in se GA. Dorsey is kicking but with their floor. I think it has a lot to do with the dealership in the area. There are many older Peerless trailers here as well. Some are heavy but they are well built. A good size local quality carrier is going with ITI. If you want a sharp looking trailer some manufacturers can do a nice job of dressing them up. I have a Keith UHMW floor. It is light, expensive, way outlasts aluminum but has its drawbacks. I don't know that Keith or Hallco is any better than the other. I can give you some pointers but I can't endorse one trailer over another. If you pm me contact info I would let you call me and pick my brain.
  8. jpracer1
    jpracer1 Medium Load Member
    439
    198
    Nov 26, 2009
    out west most guys are using TTC out of Bakersfield
  9. poppapump1332
    2,987
    2,465
    Jan 2, 2010
    birdsboro,pa
    Telling you if you want a durable trailer that will last east unloader if you want to save a little weight instead you'll pay for it in the long run although wood chips shouldnt beat the trailer too bad but if you want quality east is it.
  10. billandlori
    billandlori Medium Load Member
    357
    107
    Sep 5, 2010
    Stratford, Ontario, Canada
    In Ontario most run Titans, I have a Manac that seems to be working well. Its and '07 aluminum, I haul wood chips, scrap wood, scrap metal, crushed cars, aluminum turnings......my boss runs a lot of garbage. They have lasted really well.
    The Titans hold their value quite well.
    Bill
  11. granhawler
    296
    56
    Feb 26, 2011
    Thanks for all the info, still crunching the numbers to see if I can make this haul work. I've also thought about using a belt trailer for hauling wood chips, just not sure if I can get enough weight in the trailer.
