Walking beam to leaf air swap options
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Mr79W900A, Mar 15, 2023.
  1. Mr79W900A
    Mr79W900A Light Load Member
    117
    72
    Mar 4, 2019
    British Columbia
    Hey guys I’m looking to upgrade my 94 t800h dump truck to a better ride and full lockers and a bit lower gear From my 3:90s to 4:11. Currently have a 46k Hendrickson walking beam rte. what’s the easiest and best option to swap it with. I was thinking a neway air leaf or maybe a airliner. Trying to drill as little new holes as possible. Cutting the frame is not an option I will not do that. If any of you have done this I’d appreciate your input. Thanks
  3. OLDSKOOLERnWV
    17,806
    268,393
  4. Mr79W900A
    117
    72
    Mar 4, 2019
    British Columbia
    Already looked. They want 12 grand just for the kit. I can get a whole clip witn new gears and full lockers for 9k
  5. Big Road Skateboard
    5,687
    29,604
    May 2, 2021
  6. Mr79W900A
    117
    72
    Mar 4, 2019
    British Columbia
    She’s a single thick wall frame. I don’t want to cut it. It’s staying as one. It’s easy enough to just swap over the new suspension
  7. Big Road Skateboard
    5,687
    29,604
    May 2, 2021
    But easier and cost effective to swap cut off. Cut off every time.
    BTW, you certain you don't have an aluminum frame?
    Diesel Dave Thanks this.
  8. dirthaller
    dirthaller Road Train Member
    1,012
    11,790
    Sep 22, 2011
    Coloratah
    I’ve always thought that this would be my “dream” dump truck suspension. RTE is rare these days. Most of the Hendrickson walking beam suspensions I’ve seen on new trucks the past 25 years have been HN style which isn’t compatible with this conversion.
    OLDSKOOLERnWV Thanks this.
  9. Mr79W900A
    117
    72
    Mar 4, 2019
    British Columbia
    If they were more reasonable price wise I 100 percent would do the dual bag kit. But it’s over ten grand and it’s literally just some bags and a few other things. Way overpriced for what I can get.
  10. AModelCat
    154,260
    Airliner is simple but you will need to change out the crossmembers to match as well.
    Hendrickson Primaax is kind of a Neway knock off, I'd go that route over Airliner.
  11. special-k
    special-k Road Train Member
    1,523
    3,258
    Dec 27, 2008
    Southern Ontario Canada
    Up our way Peterbilt Air Trac is a popular dump truck rear suspension. Rides rough imo but stays in alignment for a long time and never seems to break the spring leaf.
