WABCO SPN 629 FMI 11
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Ross_Tech, Aug 31, 2021.
  1. Ross_Tech
    Ross_Tech Light Load Member
    133
    133
    Aug 31, 2021
    Has anyone had any expierence with a 2021 cascadia, with (X15/ultrashift plus) with ABS02T reporting fault 629 fmi 11? I believed I've determined it's a fault in the software of the ABS module, and I would like to see if there's an update available, but when I go to Program Device on DL8, the ABS02T is not listed, and Wabco wont connect because the only datalink to the module is freightliner Chassis CAN. How are these modules updated? Do they have to be removed and programmed on the bench?
