W900A Engine swap out .
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Briguy1980, Jan 26, 2014.
  1. Briguy1980
    Briguy1980 Bobtail Member
    Fort mcmurray alberta
    Any one done a NTC 400 cummins
    for a 3406 C cat engine with air to air
  3. that65
    that65 Light Load Member
    185
    84
    Jan 16, 2012
    Lincoln,Ne.
    Ask smokincat, He put a b model in his, though it had a Detroit originally. Or go to diesel garage.com and ask
  4. Briguy1980
  5. SmokinCAT
    SmokinCAT Road Train Member
    1,773
    1,487
    Oct 20, 2010
    Hillsboro, OH./ Adrian, MI
    Cummins to cat shouldn't be that bad, I may doubt the mounts will match up exactly though, you would have to check that by measuring and even test fitting. I had to drill the rear engine mounts on the frame side on mine with the holes that were already there. Another issue may be the clearance of the timing advance and the drivers side front frame horn, I had to notch mine.
    To to run air to air the ones I have seen recently have modified the top tank by cutting the ends off of it and narrowing it and running a peterbilt air to air from a late 80s 359 that had a factory air to air.
    That at engine in the pic looks like something from great lakes diesel, I hope not for your sake that it isn't, or the swap would be a waste of time and money. You would be better off to overhaul the big cam.
  6. Catliner
    Catliner Light Load Member
    164
    39
    Jan 5, 2014
    Thompson, GA
    I have about 5 years ago, but with a B model 3406 CAT in a 1985 W900B. Fairly easy. I made the mounts first and then put it in. Throttle linkage was made with Hardened steel rod.
  7. SmokinCAT
    1,773
    1,487
    Oct 20, 2010
    Not exactly the same, that truck had the option of a B/C model in it and being how the w900b is still being made a good number of parts are still available, not the case with a w900a.
    Catliner Thanks this.
  8. Catliner
    164
    39
    Jan 5, 2014
    Thompson, GA
    just get the mounts from an B,or L and drill new holes. the rails should be the same
  9. SmokinCAT
    1,773
    1,487
    Oct 20, 2010
    They go right in behind the cab mount on an A model, they moved the cab mounts back under the cab when they started on the w900b.
  10. Catliner
    164
    39
    Jan 5, 2014
    Thompson, GA
    so the cab mounts would be in the way?
  11. Elip88
    Elip88 Bobtail Member
    4
    I have a 71 w923a with a ntc 350 cummins. I'm in the process of purchasing a 3406B and want to put it in, in place of the cummins. I'm trying to figure out if the engine is going to fit and if i'll be able to get the air to air in front of the radiator
