W900 rough ride
Discussion in 'Trucks [ Eighteen Wheelers ]' started by opiesw9, Sep 6, 2009.
  1. opiesw9
    opiesw9 Bobtail Member
    9
    Walcott, Iowa
    I have a 2004 W900 with the newest rear suspension. I've only had this truck for a short time and have been experiencing a really rough ride. I've had front leaf springs and shocks replaced, as well as steer tires. I measured rear air ride height and it's in spec according to KW dealer. Anyone have an idea why this thing rides so rough? It's 275 in wbase tall 22.5 rubber. Front end rode great when the leaf spring broke on one side. Almost like springs are too stiff and rear drives hit hard even on little bumps.
    Possibly the ride height control?? Looks like original. I currently have 869000 miles on truck.
  3. stranger
    stranger Road Train Member
    3,640
    4,959
    Oct 10, 2006
    NC
    The brand of tires have a huge effect on ride. What brand tires do you have? On one of my trucks I had Michelin XZA 2 on the steering, and my friend with an identical truck from the same fleet had XZA 2 front tires.
    He drove my truck and could not believe the difference in the ride. He soon switched to the XZA 2 like I had, and his truck then rode as good as mine.
  4. Les2
    Les2 Road Train Member
    5,150
    2,288
    Jul 25, 2008
    kicked back in my lazyboy...
    Is this the 8 bag airride with the short bags on it? If so,thats your problem!
  5. Allow Me.
    10,642
    12,108
    May 28, 2009
    Rancho Mirage, Ca.
    Make sure the cab air bags are aired up. That's a nasty ride if they de-flate.
  6. Biscuit75
    Biscuit75 Road Train Member
    Get back on the road! Stay out of the corn fields out there in Iowa! :shaking2:
    :laughing-guffaw:
  7. opiesw9
    9
    Walcott, Iowa
    Tires are Dunlop. Ride was a little better before leaf springs were replaced. I messed with the cab airride awhile back. Less air is softer ride, right??
  8. Peanut Butter
    Peanut Butter Road Train Member
    1,343
    419
    Nov 24, 2007
    PO Dunk Idaho
    Check the cab shocks by the air bags, if they are bad you have a rough ride, but i think i would leave the cab air bags at factory spec.
  9. Heavyd
    Heavyd Road Train Member
    7,750
    6,184
    Feb 4, 2009
    If you lower the volume of air in the cab air bag all you do is lower the height. If the height is lower chances are the cab is bottoming out all the time.
    Tombstone69 Thanks this.
  10. blackw900
    blackw900 The Grandfather of Flatbed
    5,817
    7,678
    Jul 12, 2009
    A.W.O.L
    That's not necessarily true...I have 8 Bag with the short bags on it and my W900L rides as smooth as glass. I had a ride issue recently and it turned out to be the leveling valve was going out. I replaced it and the problem went away. Check your rear shocks as well 'cause they can make the ride a little choppy.
    I pull the same trailer most of the time and a few months ago I had a vibration that I couldn't find and I finally figured out that it was the shocks on my trailer...Go figure.
    I would never recommend lowereing the air ride on the cab 'cause that can make the truck ride rough as hell and it can bottom out on severe bumps and that's never a good thing.
  11. bohut1
    bohut1 Bobtail Member
    hey... my truck is giving me rough ride too its getting worse everyday.. took to many mechanics nobody found anything yet.. it bounces and shakes everything inside when its the bumps even a small bumps... got checked up everything .. kingpins, bushing, got new shocks,.. checked air bags they have proper air in those.. i think its the problem with air ride thing does any body know what it could be??? ..... how i am gonna know if the leveling air valve going out?? seems like ok .... when i ride its the same ride as truck have too much air pressure in tires i have 100 psi air pressure in tires and air bags have proper air pressure... it runs good it causes problem only on bumpy road or messy roads... can some body help me out???
