I recently had to replace the driver said wiper arm on my Kenworth W900. After replacing the wipers won’t move with the hood down since the hood is touching the arm. I tried to force the arm farther onto the spline, but it will not budge. Anyone have a similar experience?
W900 Hood Hitting Wiper
Discussion in 'Ask An Owner Operator' started by lantern756, Nov 9, 2017.
Take the arm off and turn the arm UP a notch or 2 on the spline. Yes it will look 'funny'. Take it out of the ark of the hood.
On the firewall on both sides. It is what the back of the hood rests on
If it is an areocab w9, the brackets bolted to the ribs on the hood that sit on the nipples have wallered out the bolt holes letting the hood to drop. It is a poor design. You will have to fab some metal straps and fab a new base for the brackets to bolt to. If they are you should also replace the rubber bushings and alum hinges on the front of hood as well.
Feedman Thanks this. -
Another thing if it is one of them there Aerocab trucks, if the air bags on the back of the sleeper are over filled that would put your firewall in the way of the hood.
