I own this truck for about a year and few days ago I realized that the drive tires installed are of a wrong size compared to what the sticker on the door says. The door sticker says 275/80R22.5 but tires on truck say 295/75R22.5
How does this affect the truck, especially considering it's automatic? Should I swap to the correct tire size?
Truck info:
2011 Volvo VNL
D13 with i-Shift 12 gear transmission
4x6 axles with 3.36 gear ratio
Volvo - Wrong tires size
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by vanostav61, Aug 24, 2022.
Makes almost no difference. The 295 tires you got on now are a hair wider than the 275’s. The difference in tire height is so minuscule it isn’t even funny. What is it like half an inch maybe?
I would keep the 295’s anyway because that is the most common size tire available anywhere and is much easier to keep and replace.nikmirbre, Rideandrepair, Another Canadian driver and 3 others Thank this. -
As long as all the drive tires are the same size it won't hurt anything. When tire sizes are mixed you'll be turning the differential spider gears and/or interaxle gears all the time.
I'd be more concerned about overall vehicle height if swapping to taller tires.nikmirbre, spsauerland, Rideandrepair and 2 others Thank this. -
As others have said no problems. I did the same thing to my 2014 Volvo since it was more tires that size. No issues
nikmirbre, Rideandrepair and Another Canadian driver Thank this. -
275/80r22.5 should be Michelin size. That is the same as 295/75r22.5.
Goodysnap, nikmirbre, spsauerland and 3 others Thank this. -
Rideandrepair Thanks this.
Nobody said it'll blow up? Lacking...
nikmirbre, Rideandrepair, W923 and 1 other person Thank this. -
The reason I asked is because I know that tire diameter can influence the gear ratio, mileage counting, and considering it's automatic I was wondering if it's not messing with the way transmission shifts.
Another Canadian driver Thanks this. -
.10 difference between the two.
Spicer Tire Height CalculatorAnother Canadian driver Thanks this. -
295 is just a hair bigger and heavier. Very minimal hardly noticeable. It is just a wee tad bit wider which I think you’re better off better traction.
295/75-R22.5 vs 275/80-R22.5 Tire Comparison - Tire Size Calculator | Tacoma WorldAnother Canadian driver and nikmirbre Thank this.
