2006 volvo vnl with Cummins isx. Truck will build air fine to about 60psi. Then it takes forever to reach 100 psi. It will build faster when i run high rpms. I have replaced air compressor, air governor, air dyer. Still didn't fix the problem. Itholds air for a good while but in the morning its empty. No audible air leaks. Any help will be appreciated. Thank you guys
Volvo VNL slow building air pressure
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by kabusheke2004, Oct 22, 2018.
I had this issue only on a Cat. It was some type of valve leaking on the back of the compressor. I couldn't hear it inside the cab but I opened the hood and could hear it hissing. Ended up draining all the air out and started it back up and it worked fine.
kabusheke2004 Thanks this. -
kabusheke2004, KB3MMX and boneebone Thank this.
Even though it's steel braided on the outside, it's plastic tubing on the inside, which is susceptible to cracking when it gets old, especially after you loosened the connections up to replace the air compressor and dryer, just moving the braided line a few inches in any direction will crack the inner plastic tubing.Last edited: Oct 23, 2018
kabusheke2004 and KB3MMX Thank this. -
Thank you all. I will look into the airlines. I have a feeling its some kind of airline.
You probably have some serious air leaks or lots of small ones. All trucks with air brake systems will develop leaks at the air lines “ends” eventually. I find myself repairing all sorts of air leaks every few months.
I posted this before:
Searching for air leaks is a learning experience. Every time I do it, I usually discover more air lines! If you are attached to a trailer, set your trailer brakes (chock tires if have some), air up tanks to max psi (about 130), release the “tractor” air supply (very important), spray the “ends” of air lines, that is where I have found most of mine.
There are airlines above each air bag and brake chamber. Spray them and follow the air lines to the other end. All air lines should lead to your air tanks. Your truck may have 2 or 3 air tanks. Spray the air lines on the air tanks, including the release valve of each tank. There may be air lines under the cab above the drive shaft; under the hood by the steering wheel rod; and under the radiator. Also don’t forget to look for double female adapters that some mechanics may use to extend the air line length, and I usually forget to check the two air lines that go from my truck to the trailer.kabusheke2004 Thanks this. -
easiest way I found to check a discharge air line for leaks is to adapt and back feed shop air from drier end of line into compressor with engine off. also make sure the turbo actuator which air kicks into around 90 (secondary) is no leaking from diaphragm on that ISX(it can be hard to hear but it can be felt. otherwise sounds like you got some good advice.
Try search block on the top right. We just beat this around pretty good.
