Volvo VNL D13 P269800 Code solutions ( 2014 VNL 670 )
Discussion in 'Volvo Forum' started by Classico, Feb 10, 2020.
  1. Classico
    Classico Bobtail Member
    14
    6
    Mar 12, 2018
    Hi everyone, going crazy with code. SA 16 DTC P269800
    did you get this code? and what was the solution
    Given Options:
    - Aftertreatment Hydrocarbon Dosing Module ( Dosing Manifold Assy Part. 23185531 )
    - Dosing Unit Valve ( Part. 23185531 )
    - 7th Injector ( Part. 21407621 )
    Any Help would be greatly appreciated.
  3. Newto Trucking
    Newto Trucking Medium Load Member
    359
    225
    Dec 26, 2013
    NE Illinois
    1.What year is your truck and mileage??
    2.Condition for this code: Exhaust temperature lower than expected. It’s monitoring exhaust temperature sensor at the bottom of dpf, to see its readings you need computer. Or replace it and hope for the best it’s relatively cheap.
  4. 05vnl670
    05vnl670 Light Load Member
    165
    60
    Feb 17, 2013
    My friend had this fault and root cause was an air dryer filter.
    First truck went to dealer and it was under warranty and half of the emission system was replaced. After that truck was good for little over a year same fault came back,went back to dealer and it was out of warranty, so he got an estimate for 4500$. After looking at the problem we found out that there was oil contamination in line for AHI dosing valve, we replaced the valve and installed air dryer filter that takes oil out from air not only water(wrong filter was installed at TA service), so far truck did around 40k miles no problem.
    great2c4me and Newto Trucking Thank this.
  5. Classico
    14
    6
    Mar 12, 2018
    2014 Volvo vnl 670 around d 550k millage.
    Thanks
  6. great2c4me
    great2c4me Bobtail Member
    26
    5
    May 18, 2015
    How's it going now? My 2016 just popped up with this. So it's the air dryer?
  7. rm2016VOLVO
    rm2016VOLVO Bobtail Member
    Did you find a solution for SA 16 DTC P269800
  8. stuckinthemud
    stuckinthemud Medium Load Member
    620
    3,063
    Oct 20, 2013
  9. Mdavid0614
    Mdavid0614 Bobtail Member
    27
    6
    Feb 13, 2019
    Had p269800 AHI MODULE was replaced, 7th INJECTOR was replaced, regen was done and gone
