VOLVO VNL - AIR RIDE HEIGHT( Vibration)
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by RoadRanger^^, Apr 17, 2020.
  1. RoadRanger^^
    RoadRanger^^ Light Load Member
    265
    105
    Apr 17, 2018
    Columbus, OH
    Hello good people. I was reading the whole thread about this ride height. My Volvo vnl 670, 2011 its vibrating for some reason i checked everything from driveshaft, u joints, yokes. New front springs, 10 new tires drives kelly’s and steer yokohama. New fuel pump on it. There is nothing that i can notice is loose. Like some of you guys said i went today on the lot to measure it and rear airbags from the welding to bottom of the frame 8 3/4 almost 9 and front airbags from welding to bottom was 8 1/2. What do you guys think maybe my ride is too high and cause this vibration coming under my truck and noise. Its noticeble in 6th gear and up it freaks me out everytime. I feel something will break anytime. I will also send a pic to show if my measurment is right. Thank you any andwer or opinion is welcome. Have a blessed day.
  3. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    Try pulling over when its making racket to ck if ride hi. is all the way up or down at that time when its making bad noise? It could be a bad ride hi. valve ck the arm to see if its moving on the valve without making valve move?
    RoadRanger^^ Thanks this.
  4. RoadRanger^^
    265
    105
    Apr 17, 2018
    Columbus, OH
    It was replaced 5-6 months ago. I checked the arm and its not moving it is tight. I forgot to mention 2 weeks ago my wheel seal start leaking and when the mechaninc open the wheel the nut that holds the bearing the bit one on the axle was loose he replaced the seal and tight and kinda vibration went away and now back again. I hope the nut didnt loose again. :(
